speed sensor
no you cant simulate a VSS pulse cause its a magnetic pulse that has to read a certan amount of "teeth" per second (or how ever its rated) your just gonna have to do with out vtec for a little bit.. but if you have abs becareful cause they go off of the vss so just becareful about hitting the breaks to fast
i took an auto one and had to regrind it so the pin would fit because the gear is offsetted alil deeper on the manual then the auto speed sensor. the hole dont line up ont he tranny but nothing a bolt and a walsher cant clamp down.
mrpaccmann
Feb 8, 2010 12:41 PM
