LOL, The Hooligan, you're famous!!!
Check out what I found on a Spanish Streetfighter blog...
http://customfighterspain.blogspot.c...etfighter.html
From: spinning DnB till your head explodes,jersey/philly
I did my best, there are many spanish slangs that is hard to literally translate to english.
Well, so this fighter from South Jersey (USA) has been April's winner in the CUSTOMFIGHTERS forum, and apart of its unusual looks between fighters, it may have been chosen by the great engine work it has, since in order to eliminate the SMOG system, he had to modify all the cooling and intake system, and even plug a couple valves...all big work. In this link you can see what it is like to remove the SMOG system from a CBR.
Talking about the rest of the bike, every little piece that's characteristic of a CBR has been removed, with only a minimalist seat, engine and tank, even the exhaust has been removed since it has one that was custom made and then covered in heat insulating wrap. I love this kind of fighters, since it is the minimal expression of a bike, little headlights, little warning lights, you can't see the plate, it's wicked. Here is the list of all its mods, since this is a worth bike to read because of its mods, almost everything has been removed.
TECH SHEET
Bike: Honda cbr 600rr 2007
Seat: Custom made
Rear light: Leds
Rear brake reservoir: deleted
Rearsets: woodcraft
Frame sliders: woodcraft
Tires: Bridgestone Bt016
Rear fender: deleted
Front fender: deleted
Exhaust: custom made with heat insulating wrap
Cat: deleted
Electronic control: Power Commander
Air filter: Bmc
Smog: Deleted
Smog block plates : Dan Kyle
Valves: 2 deleted
Grips: Renthal
Instruments: Relocated
Brake levers: Asv
Brake Lines: Stainless steel
Brake Pads: Vesrah Rjl
Plate holder: Padscustom
Tank cap: Vortex
Sprocket : 15 tooth
Electrical system: modified
Start switch: Aviation
Refrigeration hoses: Modified and extended
Headlights : Twin 3.5"
Paint: The Hooligan
TECH SHEET
Seat: Custom made
Rear light: Leds
Rearsets: woodcraft
Cat: deleted
Air filter: Bmc
Smog: Deleted
Valves: 2 deleted
Grips: Renthal
Brake levers: Asv
Tank cap: Vortex
Sprocket : 15 tooth
Paint: The Hooligan
the two big mods for me when i get cash again are gonna be wheels and an ohlins shock...
and get the stripping on that 250, i wanna build a 250 fighter so bad !!
heres a few pics to give you an idea.
the white one is an awesome build, he actually went to a solo fiberglass tail and lost the vfr swinger for a 636 swinger and march wheels i believe. one of my favorite svs though.
i like the tail on this black one. and the blue one is sick. just a few sv's i like...
http://www.customfighters.com/forums...t=carbon+fiber
