My power window video need help!!!
so i made this video to see if anyone could help me with this problem i got, is making me go crazy! i check the fuses but they seem to be ok. i bought a new master switch and it still doesn't work need help
link to the video
http://www.youtube.com/watch?v=rk_Aftt2rfo
link to the video
Well, first you need to pull the door panel off and check to see if you are getting power at the window motor when you push the window switch, if you are and the motor is not turning, then you need a new motor. If the motor is turning freely and the window is not moving, then the motors gear is broken and again you would need a new motor. If the motor is working and it does not move, just makes a noise, then you most likely need the window regulator. I believe it should be a cable driven one on the RSX. Let me know what happens, I should actually have both items in stock.
could it be a short in the wiring?
Dude that really sucks and on top of that the sunroof is something I have never seen before too!!!
I see what I can gather from other friends of mine who work at honda/acura cause I feel for you on those 2 problems!
2000civicsi
Oct 29, 2005 04:43 PM
