howdo I tell if the my brake booster is bad (92 si hatch)
Old Jun 11, 2009 | 02:22 PM
4DALOOKS92's Avatar
Default howdo I tell if the my brake booster is bad (92 si hatch)
well I just want to know some signs because I just change my master cylinder, after that my brakes where nice and stiff, after two weeks or so I was going 65 on the highway (not street racing, street was just emty) then I had to take my exit so I press the brakes to slow down and I felt my brakes loose preassure, then after I started driving on a 25mph street the brakes just sank with no preasure at all I pulled over and pumped the pedal and nothing. I waited like 5 minutes and then I slowly pumped my brakes again and it got the preassure back. other two weeks or so passed and same situation driving on a highway brake for slower traffic, again my brake lost preasure I dont know why it does this, it seems like it does the same thing everytime Im going fast and slow down 2 weeks or so pass by and again it happens thank you for your help.
I bench bled, bled the brakes individually in order like the manual shows so I dont know what else to do and I dont want to replace the booster if its not bad.
Old Jun 11, 2009 | 02:28 PM
Former User's Avatar
Default Re: howdo I tell if the my brake booster is bad (92 si hatch)
The symptoms don't fit with a bad brake booster. Is the brake fluid low in the reservoir? Look for a fluid leak around the master cylinder and rebleed the system. It's also possible the new master cylinder is bad. Was it new or rebuilt?
Old Jun 11, 2009 | 02:30 PM
renelovesnike's Avatar
maybe air in your break lines!
Old Jun 11, 2009 | 11:17 PM
jluo_hatchy's Avatar
check if your fluids ever run low cuz you mite have a leak between your lines. or mite just be air betwween the lines.
Old Jun 12, 2009 | 01:13 AM
4DALOOKS92's Avatar
the reservoir is full and the master cylinder is new never used Ill try bleeding the brakes once more to see what happens I though when the master c. is bad the pedal keeps sinking but mine I wait a little and pump the brake slowly and it get the preassure back like new stiff and brakes good but a period of time passes (arond 2 weeks all the time) and if im going fast and brake the pedal sinks after
Old Jun 12, 2009 | 01:28 AM
dannyboi_86's Avatar
interesting i had something similar happen ended up being the caliper boot leaking... worth having a look other than that check your brake lines from the master back... but having air in the lines is definately common also
1988_96hb
Jul 14, 2009 01:14 PM
flowgetta
Apr 16, 2009 12:09 PM
kurinto
16
May 4, 2005 03:42 PM
AzDrag1
May 14, 2003 02:53 PM
GQ Cowboy
Jul 21, 2002 10:58 PM
