Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
stripped bolt!! help!!!
Old Jun 11, 2009 | 02:15 PM
kaychi's Avatar
Default stripped bolt!! help!!!
hey there guys, i have a problem. im trying to change out my oil pan and ended up stripping one of the bolts that connects the exhaust pipe to the exhaust manifold. any ideas on how to take it off? call a couple muffler shops but they wanted to charge around 170 to take it off. please help!! thanks
Old Jun 11, 2009 | 02:23 PM
Zeusone's Avatar
Default Re: stripped bolt!! help!!!
what the does the oil pan have to do with the exhaust manifold???
you can buy a stripped bolt kit from sears or autoparts store.
Old Jun 11, 2009 | 05:58 PM
safedriver's Avatar
If your bad bolt is connecting the manifold (header) to the pipe (cat), then you should be able to grind it off and punch it through.
If your bad bolt is connecting the manifold (header) to the HEAD, then pay the $170 and don't mess with attempting to tap the steel bolt out of the aluminum head. Maybe a photo of the location will help.
Old Jun 11, 2009 | 06:04 PM
teggsr925's Avatar
this^^^
and that^^^
Old Jun 11, 2009 | 08:17 PM
safedriver's Avatar
Originally Posted by teggsr925
this^^^
and that^^^
The OP may have been trying to remove his oil pan and his manifold/exhaust system needed to be lowered, for the oil pan to clear the oil pick-up.
I have done this on other cars:
put the car on stands, then
I removed the bolts from the head, where the manifold/header is connected. The exhaust system will slide down enough for the oil pan to slide past the oil pick up.
I have not had to remove my oil pan from my 08 SI, yet.
So, I am not sure, about this car.
Old Jun 11, 2009 | 09:50 PM
xrated1's Avatar
they sell extracter sockets and lowes,,autozone,sears,checkers.
james007
Jul 9, 2010 06:53 PM
bopbop93030
Aug 12, 2009 08:22 PM
tegh22a
Aug 26, 2005 09:22 AM
fastaccord94lx
May 22, 2003 06:55 AM
GrandMarkie
May 17, 2002 12:53 PM
