Civic Cx rear disk conversion!!!
Old Jun 11, 2009 | 01:00 PM
Oem eg6 Meo's Avatar
Default Civic Cx rear disk conversion!!!
im tryin to figure out if i have to run lines from the master cylinder straight back to the rear disk or is there a junction box somewhere under the car its a 92 cx hatch ? anyone know whats the deal!
Old Jun 11, 2009 | 01:06 PM
EL Vap133's Avatar
Default Re: Civic Cx rear disk conversion!!!
What lines are you talking about?
Old Jun 11, 2009 | 01:14 PM
johnny hatchback's Avatar
no you don't. there's a break in the line where it goes from hard line to soft line right above your rear trailing arm (it actually goes THROUGH the trailing arm at one point i think), you just undo it there (look for the bracket) and hookup the integra/civic si line from there to the caliper.
Old Jun 11, 2009 | 01:35 PM
JDM_SOHC's Avatar
Hmmm, I always thought the brake fluid lines were all the same.. I don't remember ever replacing them when swappin to rear discs...
Old Jun 12, 2009 | 01:22 AM
Right on Thanks yea i actually looked at it today and saw right where the lines are it should be pretty easy!
Old Jun 12, 2009 | 01:30 AM
EF in Germany's Avatar
you did replace the porportion valve right? just asking cause you dont want to get on your breakes and have them pressure up wrong.
Old Jun 12, 2009 | 02:57 AM
jdmeg9's Avatar
the easiest way i have found to do a rear disc swap is just take the brake hubs off the rear. it is a couple of torx bolts on the back of the hub. i think that is easier than swapping a rear trailing arm. i know it has nothing to do with what you are asking but everyone is right you don't have to run new lines you just detach right where that funny clip that holds it to the trailing arm i think
Old Jun 12, 2009 | 11:35 AM
This is true.
The proportioning valve thing is debatable. I've run a rear disk swap with the stock prop valve and its fine. It only affects the balance of the braking system. For racing you want the prop valve but for everyday driving its not going to affect you much. Its not something you HAVE to do in my opinion.
Old Jun 12, 2009 | 11:56 AM
phil_lt1's Avatar
I know my 99 DX hatch has the same p/n prop valve as a 99-00 Si. So some cars don't need to upgrade. Check the part numbers on a site like HondaPartsDeals for your car if you want to know.
Old Jun 12, 2009 | 07:09 PM
jdmeg9's Avatar
Originally Posted by johnny hatchback
This is true.
the one i had on mine was 40/40 and i had the 15/16 master cylinder. integra brakes all the way around with brembo cross drills and ebc pads. my eg sedan stopped like a monster!
Old Jun 22, 2009 | 03:39 PM
OK for sure well im planning on Autocross so I want them as dialed as can be!! but some people are sayin The prop valve is not a big deal but im thinkin it is because its a distribution of fluid to the caliper and the integra has a way bigger piston than my stock brakes?
Old Jun 23, 2009 | 07:51 AM
on the ek the prop valves are all the same, on the eg/eh chassis the prop valve is different for cars that came with rear disc (si/some ex's) and i believe it is the 40/40 on those cars, you can swap it from one of those or an integra w/o ABS... i think the 90-93 prop valve is the same (and 4040) but in a different location, if i remember right all the lines would lineup on the eg...if you are going to autocross you might consider swapping it.
Old Jun 24, 2009 | 01:18 AM
Alright for sure Thats legit yea i picked one up yesterday, and yea the 90-93 w/o abs is what i have heard to run is good on my car! thanks for the advice. so lemme ask this One of my rear disks that i have is LOCKED like the other one spins but this one dont could the e brake be on inside? cuz the arm is off the car so?
Old Jun 24, 2009 | 02:28 AM
jdmeg9's Avatar
yeah i had the 40/40 on my eg sedan and it fit perfect and it was from a da
Old Jun 24, 2009 | 07:25 AM
the caliper is probably stuck, take it off and use that weird tool to spin it back. Test this out when you do the swap, those things notoriously stick... i did a rear disk swap on my friends car with some parts i had laying around for awhile and two calipers on the same side were stuck so i ended up having to pull another one from the junkyard.
Old Jun 24, 2009 | 01:27 PM
jdmeg9's Avatar
you can rebuild them. the kits are fairly cheap. i went ahead and had the new rings and stuff put in mine before i did it so i only had to put them on once
immajackuup
Jun 27, 2008 07:43 AM
naylor16
Apr 7, 2007 06:09 PM
team w o t .com
Jul 26, 2003 05:18 AM
madhatter
11
Jul 22, 2003 05:20 AM
MisterB
Dec 4, 2002 09:52 PM
