vss & alt problem
vss & alt problem
so after i finish my H2b swap in the civic my alternator seems to be on the fritz because the battery light stays on untill i rev it up past 6000 rpms. Now i've tried 3 working speed sensors and checked all the fuses and conections and all seem fine. if the alt is not charging right would this really affect the vss???
Re: vss & alt problem
What's wrong with the VSS? Do you have a CEL code for the VSS? Does the speedo work?
Regarding the battery light, your alternator most likely needs to be replaced.
its a 92 .. the vss is bouncing around.. we had it tested in another car and it ran fine! yes i had a code for vss but not with the new one yet because its on jack stands still!! im getting a new alternator tomorrow so we shall see
blue_hatch
17
08-07-2013 04:51 PM
