Threw a Rod Swapped the Motor & Wont Start
Old Jun 11, 2009 | 11:50 AM
OUT OF ORDER ROB's Avatar
Default Threw a Rod Swapped the Motor & Wont Start
So i Threw a Rod and Got the Car towed home.
Swapped out the longblocks Now Wont Start.
No Fuel or Spark But has power Going Through the Wire to the Distributor But wont Spark
Has power* Going to Fuel Pump Relay But no Power @ the Pump
CHanged out ECU
CHanged out Distributor
Changed out Main Relay
Changed out Spark Plug & Wires
CHanged out fuses
CHanged out Battery
CHanged out Fuel Pump.
What Else could it be?
Old Jun 11, 2009 | 05:01 PM
jhammond_82's Avatar
Reject Papi
Default Re: Threw a Rod Swapped the Motor & Wont Start
any codes on the ecu?
Old Jun 11, 2009 | 07:23 PM
paton5g's Avatar
What's the car, year, engine? More detail...
Old Jun 11, 2009 | 11:20 PM
Hmm i will have to check that tomorrow.
94' 4dr DB7 Had a Lsvtec before now swapped a 98' GSR But swapped everything over to OBD1
Old Jun 13, 2009 | 12:05 AM
NObody?
Old Jun 13, 2009 | 01:52 AM
seanbev24's Avatar
How are your grounds? Especially the one on the thermostat housing
Old Jun 13, 2009 | 02:51 AM
lazyvietboi's Avatar
i would check if there are any cel's. does it crank? might want to check the fuel pump to hear if it primes.
Old Jun 13, 2009 | 11:10 PM
i CHeck the ground like 5 times all Bolted down.
it cranks but wont Kick over.. Fuel does not prime.. even when i run a Straight power to the fuel to prime it still Wont kick over because of no spark.
Old Jun 13, 2009 | 11:15 PM
ekb16a's Avatar
ur dizzy
Old Jun 14, 2009 | 02:01 AM
vegas's Avatar
Originally Posted by ekb16a
ur dizzy
I'm gonna say the same thing..
About 6 months ago I had the same problem on my 99 EX. Could not figure it out to save my life. Then I took apart the dizzy and found some arching on the inside of the cap. Realized I had an exposed wire causing it to spark inside the cap..
Old Jun 14, 2009 | 04:59 PM
please update when you find the problem.
Old Jun 23, 2009 | 11:54 AM
i changed the dizzy twice not the problem i have power going through the wire harness all the way to the dizzy but wont fire,
Old Jun 24, 2009 | 12:46 AM
help
Old Jul 27, 2009 | 08:54 PM
uratom's Avatar
Pmed!
Old Jul 29, 2009 | 11:30 PM
Replied!
Leo Bracamonte
Feb 4, 2015 04:05 AM
Tatooine
Jun 27, 2010 07:00 PM
jstafase
Jun 15, 2009 09:15 PM
hybridmath
30
Jul 20, 2008 03:38 PM
520_Motorsports
Jan 20, 2008 12:21 PM
