best spark plugs for a gsr?
Old Jun 11, 2009 | 11:24 AM
93 del slo's Avatar
Default best spark plugs for a gsr?
hey guys was planning on doing a tune up what are the best spark plugs for my b18c1?
please and thanks in advance
Old Jun 11, 2009 | 11:37 AM
xsteinbachx's Avatar
Default Re: best spark plugs for a gsr?
Just buy some NGK's, and if you're asking whats the best NGK? Whatever type you can afford.
Old Jun 11, 2009 | 11:40 AM
shailoche's Avatar
I would recommend either NGK IX Iridium BKR6EIX or Denso Iridium IK20. Both of those are the highest quality plug you can get. They use a fine wire Iridium electrode which is very high performance. They can be a bit pricey, the NGK being about $8 and the Denso being about $12.
If you want a Platinum plug I would stick with the Denso Double Platinum PK20PR-L11 or NGK Double Platinum PFR6G-13. The Denso would be about $7 and the NGK would be about $12.
There isn't a huge savings by going with a Double Platinum plug but they will last a little longer than the Iridium. The Iridium gives a better spark and flame front which makes it a higher performance plug.
The only thing to be careful about is that some Iridium plugs are not suited to use with nitrous systems.
Otherwise, you can't go wrong with either one. If you want good prices on these plugs you can get them online and in most Autozone shops.
When I shopped online for my plugs I got them at www.sparkplugs.com
Old Jun 11, 2009 | 11:49 AM
trustdestruction's Avatar
NGK V-power is fine. For $8 a set, you can't complain. Don't waste money.
93 del slo's Avatar
ive heard it would be better to go one step colder than stock any truth behind it?
Old Jun 11, 2009 | 11:56 AM
shailoche's Avatar
If you are racing or are going to be doing a ton of high speed driving then one step colder is a good idea. Otherwise just stick with stock replacements or a high quality platinum or iridium plug.
Old Jun 11, 2009 | 11:57 AM
EL Vap133's Avatar
I agree, they work for me.
Old Jun 11, 2009 | 12:07 PM
Skip01's Avatar
Added to the original question, what do yall suggest for gap?
Old Jun 11, 2009 | 12:08 PM
EL Vap133's Avatar
I stick with what it says under the hood, 1.1mm.
Old Jun 11, 2009 | 12:09 PM
^ditto
Old Jun 11, 2009 | 12:37 PM
93 del slo's Avatar
same gap for a gsr?
Old Jun 11, 2009 | 01:38 PM
civic_driver's Avatar
Check NOFX's post about what the OEM spark plugs should be in this thread: https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/spark-plugs-2534718/
As far as the gap goes, it's 0.052" according to NGK: http://www.ngksparkplugs.com/part_fi...t.asp?mode=nml
Old Jun 11, 2009 | 02:02 PM
kulo's Avatar
what about ngk copper v-groove?
ZXiPoZ
May 3, 2012 09:25 AM
superhatchbackbros
Sep 10, 2009 10:06 AM
katzenjammer84
Honda Civic (2001 - 2005)
Jul 8, 2009 07:55 PM
Calean007
May 9, 2005 07:04 PM
Greg James
Aug 18, 2004 05:18 AM
