alarm install on 4dr db8
Old Jun 11, 2009 | 01:49 AM
KCUF_DB8's Avatar
Default alarm install on 4dr db8
i am going to attempt an alarm installation and will need some help from my fellow ht members.
items in hand
- peizo sirens
- matrix 1x 2-way
- back up battery
i am going to start and am wondering why in this picture there is a relay shown? http://causeforalarm.thecarthing.com...arm_prep_4.jpg
i'd like to know what connects to it and everything. if you guys have a better write up please let me know going to pull my dash tomorrow!
Old Jun 11, 2009 | 04:56 AM
fcm's Avatar
fcm
Old Fart
Default Re: alarm install on 4dr db8
Actually it is 2 relays, [in one package] it is DEIs door lock relay pack, [DEI 451M], not needed if you have stock power door locks. 94
Old Jun 11, 2009 | 06:00 AM
RyanA's Avatar
Do a search under my user name. I recently started a topic about how to secure your car before it gets stolen. First off, DO NOT put our alarm brain by the steering column because that is the first place the thief will look for it. HIDE IT somewhere that is a PITA to get to. If you have the extra time, put it inside one of your doors, behind the passenger airbag (you'll need to remove the bag to get it back there. When I say behind, I mean between airbag and firewall, above climate control box), in the trunk. Put your relays in a separate location, not with the alarm. Buy a roll of black wire and terminate each wire, one at a time. When you are done, try to bundle the wires with factory ones then cover with black tape trying to maintain the same pattern the factory did. Make sure your light flash is fused. Instead of just doing starter kill only, consider starter kill, main relay kill, and fuel pump kill (3 separate relays). HIDE your siren and make it hard to get to the siren itself and the wiring. If you are going to put the siren behind the bumper, consider running the siren wire through the frame rail so the thief can not get to it.
Good luck on the install. Take all the time you need; the more thorough you are with your install, the better protected your car will be. Remember, no matter how good your alarm is, it's only as good as its install in the end. You can take a $50 alarm that's well installed and it will protect your car better than a $500 system that was just slapped in by your steering column.
Old Jun 12, 2009 | 09:36 PM
kelviiv's Avatar
stealthhh
Old Jun 12, 2009 | 10:12 PM
KCUF_DB8's Avatar
thanks for the advice
so i am prepping all the wires and i have a few questions.
i have connected the back up battery and i am wondering where the red wire goes with the inline fuse connected. it says into a constant 12v so i am suppose to extend the wire?
also what is the white wire with an inline fuse used for/connected to?
i have the green wire which says to a negative door input trigger.
also on the starter kill, while i was reading the manual it says to add a diode to the orange wire? is that required? where does the yellow/black/green wire located to?
will post pics up in a minute,
http://img41.imageshack.us/gal.php?g=img3897g.jpg
Old Jun 13, 2009 | 05:01 AM
RyanA's Avatar
Did you not get an install manual with your battery backup or alarm? If it's an older DEI, it should have all of the wiring info on the pieces. On the starter kill relay, the orange wire goes to the orange starter kill output, the small yellow goes to switched ignition (or the switch side of the starter kill relay). The large wire at terminal 87a goes to the key side of the starter wire. The large wire at terminal 30 goes to the starter side of the starter wire.
On your battery backup, I need to know the brand so I can make sure I'm giving you the right wiring info... You need to make sure to hook up EVERY wire on the battery backup so it can do its job, too...
Old Jun 13, 2009 | 06:38 AM
Cole D's Avatar
I'd be willing to bet its an DEI backup battery 520T
Old Jun 13, 2009 | 07:36 AM
KCUF_DB8's Avatar
the back up battery is 520T
Old Jun 13, 2009 | 03:43 PM
RyanA's Avatar
red:+12 constant
gray:goes to +12 of alarm
blue:instant trigger of alarm
black:ground
Old Jun 14, 2009 | 01:39 PM
KCUF_DB8's Avatar
what are the solid green and white wire connect to?
Old Jun 14, 2009 | 02:03 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Solid green goes to the door trigger and white goes to the parking lights. I would run a relay on the parking lights wire from the alarm brain so the parking lights do not flash when the battery is unplugged.
Old Jun 14, 2009 | 02:47 PM
KCUF_DB8's Avatar
thank you, i will do that for the parking light. makes sense
ive hooked up 3 sirens and added a 2amp inline fuse for each.
i will look at my alarm tonight and figure everything out.
keep you guys updated!
chrisfromsrq
Audio / Security / Video
Jun 29, 2009 05:40 PM
fryman
24
Sep 17, 2008 11:49 AM
winkwitstyle
Dec 21, 2007 10:29 PM
ny153
Oct 18, 2006 11:40 AM
