b20vtec partoutand some miscparts for sale
94 ls long block has low compresion on #3 cyl needs rebuilt $200
gsr injectors $40
b20 crankshaft already micro polish $150
stock gsr rods w/ycp high comp. piston standard $150
0bd1 p75 ecu chipped $120
2 obd0 pr4 ecu $50 ea.
LS SLEEVED BLOCK 86MM BUT U HAVE TO GO 86.5MM COMES WITH Z10 GIRDLE ASKING $450
gsr str intake manifold $200
obd1 ls engine harness $100
stock gsr camshaft $50
obd1 ls distributor $120
stock gsr springs and retainers $50
stock type r dual valve spring $120
90-93 INTEGRA HALFSHAFT $50
d series lightweight flywheel $50 soldddddddddddddd
eg6 jdm power folding mirror complete w/ relay and switch $200
eg6 jdm doors white comes w/ power window/ no glass or panel $150
jdm bumper pole comes w/ switch $180
b20 vtec specs
gsr head p&p by dave @dnr $800 THATS JUST FOR THE P&P the price is for the head only.. comes w/ valves and atock gsr spring and retainers already tapped for vtec conv.
sk2st2 cams w/ blox cam gears $500
blox dual valve spring & retainers $200 cams ,camgear and springs retainers $600
vistor x manifold/blox 70mm tb $500 port match w/tb 70mm
aem fuelrail/rc 310cc/ $300
ssr side exit $700
msd 6al /msd blater coil $300 comes w/ distributor
valve cover breather kit comes w/ valve cover brand new $250
golden eagle vtec conversion $200 almost brand new
b series shift linkage comes $50
b20z block bored 85mm
blox magnetic drain plug
new oem water pump
new oem seals
stock ls rods w/ ard rod bolts
rs machine type r
micropolish crank
oem bearings
type r oil pump
COMPLETE SHORTBLOCK $1300 100% NO PROBLEM
type r tranny 4.4 fd $1200 asking $900 100% no problem
stg 2 exedy 3 puck $480 brand new asking $200
toda light flywheel $250
tuned by dave @dnr
s200 hondata $300
or buy the complete swap for $5500
made 236hp 154trq
ran 11.8 qtr mile @112 mph
1.6 60ft
used about 1200 miles so far
if interested call me at 5103143032 name is ryan thanks............... u guys are welcome to come check the motor
the motor still running rightnow,......... willstart to take it apart nextweek
also have gsr longblockfor sale
i have jdm gsr longblockfor sale
it has 80k
last compresion before i took out the motor 210 psi on all cly's
100% running condition im willing to make a bill of sale for this motor and also u will pick this up at my house
asking $1200 obo
gsr injectors $40
b20 vtec specs
ssr side exit $700
new oem water pump
new oem seals
rs machine type r
micropolish crank
oem bearings
type r oil pump
tuned by dave @dnr
s200 hondata $300
made 236hp 154trq
1.6 60ft
it has 80k
asking $1200 obo
lakaspeed
Northern California (Sales)
Jul 26, 2009 08:50 AM
lakaspeed
Sep 17, 2008 09:04 PM
