repainting
honestly my car is faded and i need to fix it. up.
as you can see here i need a paint job.. .its like that all the way to the top;.and to the rear. only on the top from sun damage..
paint is so expensive is there anything i could do to make it look good and cheaper?
what is a good paint shop? maaco? and estimated how much?
would it be cheaper to get a carbon fiber hood?
sorry for the screaming. lol.
you would only need half a gallon of paint which should only run you about $70 - 80 plus a clear coat kit. 180 grit sand paper 400 grit wet sand... if you do all the prep work your srlf it shouldn't run you any w=more then 100 to repaint the damage areas.
Best paint to go for is WANDA and a good clear coat is Finish 1.
btw where do you live.
i have a 94 black LS and i'm repainting it championship white with a pearl. if you live in GA i can help you out very cheap
YOU'DE BE BETTER OFF GETTING IT BUFFED OUT AND CLEAR RE CLEAR COATED. BUT IF YOU BUFF IT AND IT DOESN'T BEGIN TO GET IT'S NATURAL SHINE BACK THEN YES YOU WILL NEED A PAINT JOB...
i have a 94 black LS and i'm repainting championship white with a pearl. if you live in GA i can help you out very cheap
im in l.a like alhambra area.
i live near GA.. Glendale?
Da*n sun, my wife's teg is getting a paint job here in the next few weeks. I wanted to change the color to the Acura pewter color but that cost a whole lot more. So I'm thinking having it painted to original silver maybe a shade darker hardly noticeable and a dark blue pearl sprayed on it.
Maaco can possibly be good, if you go in and tell them what you're looking for, and talk to the person whos going to be painting it, tell him that you're really concerned with the outcome, shoot him a $100 tip or something before he starts and it might come out decent. I was gonna do maaco, got a quote for $750 with all body work for a single stage paint job, ended up just going with a local on the side painter whos known for amazing work for $2000 out the door with all body work with Sikkens base/clear milano red. Itd be best to find a guy who does it on the side and tell him you want a cheap single stage job but the prep work done right, if i was in your position.
Btw my hood/roof/trunk looked about like yours, and plenty of dents to go along with it lol i had to do something about it.
try summit racing. i did a build thread on my ef hatch a few months back. i'd use their paint anytime. awesome outcome. and its only around 70 bucks a gallon. or if you have a baps near where you live, i'd try them too.
Where do you live?
700 is so more reasobale for me.. and even though the 2k is lifetime. the maaco paint is 700 and will last like 5 years and well i can paint it twice for 1400 its so much more reasonable
if you have a garage at your house, or access to one, you can make your own paint booth. i did it when i painted my car. total cost in paint, and supplies, was only around 270 bucks. i paid 500 bucks to my buddy to do all the rust repair and to shoot most of the paint on the car.
and its a spot painting so i have to match it.. no?
if it just the whole front end and roof. then you can just blend the front into the doors. but if your deck lid is faded too just paint the whole car. imho i would just paint the whole thing anyway
my max is like 600 to 800... and if i do paint the whole thing i should just change the color. hahah
is it cheaper to do spot painting or to have the overall thing done.
$2000 just to respray a car? thats a bit high you could get a JDM conversion installed and painted for that price. if theres no body work i say wet sand it at work yourself buy the paint through your job so its cheaper. then just have someone there spray it. i bought a gallon of omin plus cypress green pearl, gallon of clear, and harder cost me $360 thats at dealer price which you should be able to get working at a shop. and there is alot cheaper paint then that
well spot painting in your case would almost be the whole car. Trying blend it will be tough to. IMHO Id fix any dents myself then seal my body work wet sand the whole thing up to 1000 grit. DONT CUT THROUGH TO METAL or youll have to seal the bare metal spots. Then take it to your work tape it off and base/clear it youll be much happier with the outcome. When it come to body work the time spent prepping is what makes or breaks you. That said anything that will come off with relatively easy take it off before you paint. Nothings worse than seeing tape lines next to seals and moldings......
