00 Civic sedan worth building?
Hi,
I have a civic sedan and was wondering what you guys think about building it for the track. Not to concerned about looks or power but mainly about the balance of the car. I would think that because the vehicle is a bit heavier than than the hatches it would have a bit more traction with the right suspension and what not? so back to my original question. If power is not an issue (would immediate swap out engine) than would the over all body or chassis hold up on the track? is over all appearance of the vehicle the reason that sways people from building it.
thanks
Johnny
thanks
Johnny
Hi,
thanks
Johnny
thanks
Johnny
Overall, there is nothing wrong with a sedan for racing, just different than what is typically seen.
ahhh I didn't account for the momentum of the vehicle. sigh. p=mv. makes sense. increase mass and velocity = greater p, which then would require larger wheels with higher level of friction to keep the car from sliding . but tires only get so big and would need, im guessing, higher grade wheels, which probably cost more than you're normal street tires. but then we would have to factor in the wheel size of the tire to performance. wow. this is all harder than i thought. thanks for the insight. Ill keep looking around for the perfect formula for my civic.
Compared to the hatches, the 4 dr, the average weight differences is give or take 200 lbs. So pulling out the ac and stripping the car down would, would possiblily bring it down to an unharassed hatch? i dont want to build a loser. haha would appreciate some more input
thanks
thanks
Most classes of racing specify a race weight. People use ballast to get the car heavy enough to compete.
Don't overthink the weight thing. I was only trying to point out where you went wrong.
Given 2 Civics, 1 a hatch and 1 a sedan, both with the same engine and race weight, both restricted to the same sized tires and brakes, I'll take which ever has better aero.
What are you trying to do with the car anyway? If its just an HPDE car, go drive and ignore the "which car would be better" concern. If you have an intended class you wish to race in, you'll need to know all the rules to make any form of decision.
) an Integra sedan, also with great success.
Sedans are stiffer.
I don't think that's going to overcome 200lbs, or be as much of an issue with a cage added, but that's what I tell myself and my beloved GSR sedan..
blue civic 4 door in h1
4 door integra that won H1 in 2007
tl that was movin well at nat'ls last year
Check the weights, some of the years the 4dr was lighter than the hatchback Si model. I personally think the 4dr has better aero than a hatch and would run it down on the straights, but a CRX would be better than both. I've driven a 4dr daily for years and I like the way they handle better, I think the weight further back helps the rear end "rotate" in the corners a little easier for better turning.
the sedan's longer wheelbase will have more high speed cornering stability, and like some have said the sedan style chassis is stiffer then the blank rear hole of a hatch back. it comes down to what your into. Id rock the sedan
That long *** gets a little more pendulum affect in turns IMO, several of the locals who have had HB's, coupes, and 4dr's all prefered the 4dr handling, many can't even tell you why or explain, but just felt they handle better.
The longer wheelbase will be more stable in turns, which could also be translated as more difficult to rotate. That pays off in high-speed turns, but is frustrating on the lower speed stuff. Like Jimmy said, give and take.
^thanks for the clarification, sam3e goes with the focus chassis, 2 door hatch, 4 door hatch, and sedan have the same wheelbase despite they dont seem to from a glance. well then i guess since the wheelbases are the same, that part of the debate is put to rest, but the fact that the sedan body most likely still has a stiffer chassis by design, id say YES its still worth building
I say go for it. In the Philippines we have a lot of people that race with that chassis. Yes it is more common here, but we also have a lot of other chassis to work with as well. I've worked with and seen some sick 00 Civic sedans here. Do it, it'll be fun.
Rratedcivichatch
16
May 7, 2011 05:46 AM
B16B_coupe
17
Nov 27, 2006 01:09 PM
Rratedcivichatch
15
Oct 20, 2002 09:15 PM
