got a new 90 ef with crazy acting mini me
Old Jun 10, 2009 | 01:39 PM
Purplelv's Avatar
Default got a new 90 ef with crazy acting mini me
ok i posted before but that was with just what the guy told me
ok its zc bottom with a vtec head the only numbers i found on the head was p06
its a pm6 ecu
it starts and idles fine but if i give full throttle it bogs down to nothing the
the vtec isnt hooked up and for right now i think its best
and sometimes well most the time it smokes like uncle bucks car
any clue to whats wrong with this car other than it should be taken to a junkyard?
Old Jun 10, 2009 | 02:31 PM
blazzer's Avatar
Default Re: got a new 90 ef with crazy acting mini me
sounds like a good project car tahts for sure
Old Jun 10, 2009 | 10:31 PM
Purplelv's Avatar
yeah i was more hoping to get an idea of what could be wrong....i know its a project
Old Jun 11, 2009 | 01:07 AM
Redline130's Avatar
There is a good possibility that your timing is off. Also, unless the PM6 ecu is rechipped or something, you won't have vtec anyway. Just by chance, do you have a picture of the engine? Or just an engine bay shot?
Old Jun 11, 2009 | 01:46 AM
Purplelv's Avatar
i will try to get pictures tomorrow
Old Jun 11, 2009 | 05:17 AM
dephtone's Avatar
What color is the smoke coming out?
Old Jun 11, 2009 | 11:54 AM
Purplelv's Avatar
its a white light grey, and there is oil building up in the tailpipe also but it still like runs pretty strong
Old Jun 11, 2009 | 11:57 AM
4drEF's Avatar
Keyboard Humorist
Get your vtec hooked up and a proper mapping for that setup.
A stock P28 map would do much better than what you have.
Just because you don't have vtec hooked doesn't make it a Pm6 worthy head - the cam has totally different profiles than what that ECU is looking to serve.
Opening up on it without proper mapping - not even surprised it bogs
Other than that you need to crack that engine open.
It's a far off chance that your PVC valve is failing - most likely you got a blown headgasket, cracked sleeve, bad rings... etc.
Old Jun 11, 2009 | 11:58 AM
Radim's Avatar
Either...
1. Headgasket is bad.
2. Head is warped.
3. Head is cracked
4. Block is cracked.
5. ECU or injectors is bad and giving not enough fuel/too much in which case it would be blowing black smoke or greyish smoke
Old Jun 11, 2009 | 12:08 PM
Purplelv's Avatar
yeah seems like a bummer guess start with a p28 and if that doesnt work off comes the head
Old Jun 11, 2009 | 01:00 PM
4drEF's Avatar
Keyboard Humorist
BTW - if that P06 is chipped then you can convert it to operate vtec.
http://xenocron.com/install/index.htm
check out the 11F0 and 1720 kits. you will need to figure out which one you need for your ECU.
They also do chipping - you should look into that so you can get a tune done or at least a decent basemap.
Old Jun 11, 2009 | 01:33 PM
Purplelv's Avatar
i just went out there now that its daylight and i had an idea what to look for and the oil has gas it in it and all its new oil....does that narrow it down any? also i just took the valve cover off and its got tons of gas in the head
Old Jun 11, 2009 | 07:01 PM
EJ1_Sleeper's Avatar
not to be the bearer of badnews but that head isnt a vtec head? p06s are non-vtec.
usually gas in the oil is a good indication of bad rings. get us some pics of your motor and the back side.
Old Jun 11, 2009 | 07:46 PM
Purplelv's Avatar
oh i dont care if its non vtec but it has a solonoid and of course its says vtec lol yeah i am trying to get a damn camera
Old Jun 11, 2009 | 10:16 PM
Purplelv's Avatar
this is all i got its what he sent me on a cell phone so its not the best angle or detailed but will maybe help
Old Jun 11, 2009 | 10:41 PM
dave181's Avatar
that is a vtec head how much didi u pay for the car anyway
Old Jun 11, 2009 | 10:44 PM
Purplelv's Avatar
nothing i had an old 1985 cutlass laying around that i traded
Old Jun 12, 2009 | 12:02 PM
Purplelv's Avatar
Old Jun 12, 2009 | 01:51 PM
skipbudlong's Avatar
get a better picture.
Cass_EF
Jul 25, 2016 03:37 PM
jharris29
Sep 27, 2012 08:03 AM
Purplelv
Jun 12, 2009 10:13 AM
contractkiller
Feb 29, 2008 06:07 PM
iphatcrxi
Nov 23, 2004 07:14 PM
