rmf narrow replica + T1R 63 catback = which T1R resonated test pipe????
Old Jun 10, 2009 | 01:19 PM
hondatuner020's Avatar
Default rmf narrow replica + T1R 63 catback = which T1R resonated test pipe????
as the title says i plan on running a rmf narrow replica from vteckid (already ordered) and the T1R 63 catback (designed to fit 97-01 type r's) on my integra..
i was told the rmf header is the same length as the oem jdm 4-1
so you would think i would need the jdm length to bolt it all up... dave from R&D motorsports told me that i actually needed the usdm length...
any help on which on i need?
Old Jun 10, 2009 | 01:49 PM
BlueIntegraBoy's Avatar
Default Re: rmf narrow replica + T1R 63 catback = which T1R resonated test pipe????
If the RMF narrow is same length of JDM, then depending on the catback will decide your test pipe length. If the catback is for USDM ITRs, then you will need a USDM length.
Old Jun 10, 2009 | 09:40 PM
tech0937's Avatar
Check this out mdpsEG's car.
https://honda-tech.com/forums/showth...434887&page=24
scroll down to mdpsEG's post, see that picture. Its a T1R 2.5'' B-pipe and T1r 2.5'' test pipe that bolts straight on to the RMF replica perfectly. It's on is a 95 integra. Get that same B-pipe and test pipe set up and you won't have to worry about fitment. message him and I'm pretty sure he'll help you out.
Hope that helps.
Kruzer
Mar 13, 2011 08:31 PM
Phatch99
May 25, 2006 05:56 PM
Shaka01
Feb 26, 2006 11:56 AM
Tippyman
Dec 21, 2005 07:30 PM
92TypeR
Mar 1, 2003 04:42 PM
