tire clearance
Old Aug 20, 2002 | 11:13 AM
vietboionfiyah's Avatar
Default tire clearance
hey guys i'm new to this so i need some help
i have a 99 civic and i lowered my car about 2.0 inches and i just put some rims on it. the rims size is 17x7 and i have 205/40 17 tires on it and it seems to rub but it does seem to be the rubbing on the outer wheel well. i'm guessing it something around the back of the wheel well area but not sure..plz help
Old Aug 20, 2002 | 12:04 PM
BigZ88's Avatar
Default Re: tire clearance (vietboionfiyah)
yea pretty much anyone running a lowered car with 17" wheels is having this problem, there are a few things you can do to fix it:
1. If u want to keep ur wheels, Roll your fenders.
2. Get smaller wheels
3. Raise your car back up
4. Cut out your fenders, add flares and get a camber kit (not sure if this would work or how it would look, but i have thought about it)
You could also try beefin up your suspension with stiffer springs/struts. perhaps sway bars.
Old Aug 20, 2002 | 12:11 PM
PSU's Avatar
PSU
formerly DxHatchback
why does everyone have problems with rubbing? i have an eh2 with 17" rims and no rubbing at all.
i rolled my fenders the ghetto way and i have tokico illuminas
i believe the illuminas help a lot
Old Aug 20, 2002 | 12:15 PM
BigZ88's Avatar
Default Re: tire clearance (DxHatchback)
if you rolled ur fenders you shouldnt rub..
oh yea and struts should help too....although i dont like illumas
[Modified by BigZ88, 9:17 PM 8/20/2002]
Old Aug 20, 2002 | 12:35 PM
monicle's Avatar
i have 17" enki rs6 and i had the same problem. i corrected the camber and got lower rear controll arms from specialty products and it still was rubbing a tiiiiiny bit so i just took off the little rubber sleve on the fender lip and it was fixed.
Old Aug 20, 2002 | 02:05 PM
BigZ88's Avatar
Default Re: tire clearance (monicle)
how do you like the specialty products lca's?
Old Aug 20, 2002 | 02:43 PM
thx everyone for the help
i rolled my fender and theres no more rub...alrite
Old Aug 20, 2002 | 05:23 PM
deepnite's Avatar
shelf the 17 s..tires are heavy enough with having to add all that metal to it
stinkypinky1011
Honda Civic (2001 - 2005)
37
Dec 19, 2007 07:42 AM
civboy115
17
Mar 16, 2004 02:03 PM
gohandbz
Mar 29, 2002 08:47 PM
dra_phantom
Mar 23, 2002 11:48 AM
ryand16y8
Mar 13, 2002 07:06 PM
