B16A OBD1 into 98 Civic EX, jumper harness???
Old Jun 10, 2009 | 07:14 AM
T3KNiQe's Avatar
Default B16A OBD1 into 98 Civic EX, jumper harness???
I putting an HMO B16A OBD1 swap into a 98 Civic EX and would like to buy a jumper harness somewhere so I don't have to mess around with the wiring. Obviously I want to back date the car. So what legit site can I buy it from?
Old Jun 10, 2009 | 07:27 AM
RyanA's Avatar
Default Re: B16A OBD1 into 98 Civic EX, jumper harness???
I've always used a guy on Ebay. His user is JDM1810 or JDM1815. He is very cheap on harnesses and most of his harnesses use OEM (AMP) plugs. In case you did not know, you need an OBD2A to OBD1 conversion harness.
BTW: an alternative to getting the conversion harness would be to get a 96-97 del Sol VTEC (B16A3) ECU. You would simply have to do the CKF bypass since your engine does not have the provision for the Crankshaft Fluctuation Sensor. 5 minute deal to do the CKF bypass and you still have OBD2 diagnostics on board. I'd only go to OBD1 if you intend on having the car tuned. By tuned, I don't mean buying a chip on Ebay....
Old Jun 10, 2009 | 07:45 AM
T3KNiQe's Avatar
Thanks bro good info,
real quick what throttle cable do I use? Stock or 99-00 Si?
Old Jun 10, 2009 | 08:20 AM
RyanA's Avatar
99-00 Si cable and throttle bracket. Throttle bracket will have P2T on it. The regular B16 one on your engine right now MAY work but, to be safe, I'd get the 99-00 one.
Old Jun 10, 2009 | 11:00 AM
T3KNiQe's Avatar
Thanks
Old Jun 10, 2009 | 12:05 PM
yoontim23's Avatar
Buy the conversion harness from jhpusa.com I heard alot of the ebay wires come loose very easy.
Old Jun 10, 2009 | 12:26 PM
RyanA's Avatar
Yes, you are right. That is why you want to only buy conversion harnesses that use OEM Honda connectors. If they have some cheap trash plugs, they can definitely make you mad. I have a friend that got a cheap conversion harness and his car would miss. Come to find out, when you wiggled the conversion harness, it would start hitting on all 4 again. It ended up being one of the injector wires was getting an intermittent connection.
Old Jun 10, 2009 | 02:16 PM
bigD's Avatar
had the exact same problem with a cheap harness
Nermin
Sep 29, 2010 04:50 AM
Civic483973
12
Jun 11, 2010 08:55 PM
EK8D15B
Sep 4, 2007 09:24 PM
DFW
Apr 30, 2006 07:37 PM
v8 integra
Apr 20, 2006 05:16 PM
