Is there a/c wiring in a non a/c EG Si from North America?
I have all the components to install the A/C but I don't know if the Wiring harness for the Air conditioning is there. Its a 93 EG from North America that didn't come with a/c standard. T.I.A.
ya its there you need the last half of the wiring the plug is behind the air box plugged with a white cap clipped to the wiring harness. also youll need the A/C button from another EG you dont have to replace the cluster just insert the button. top right corner of your cluster carefully pry the grey little cover plate off and insert button.
5poonhatch
May 30, 2005 06:28 AM
