what engine swap to do
Old Aug 20, 2002 | 10:24 AM
burnett999's Avatar
Default what engine swap to do
I am planning on doing an engine swap I want a fast car for the 1/4 mile I dont care all that much about top speed, I am problably going to spend about 2000 from the start just for the base engine to build on what should i go with, any opinions would be great
thanks
Old Aug 20, 2002 | 10:50 AM
KEVlN's Avatar
New User
Default Re: what engine swap to do (burnett999)
b18a1-fast quarter mile not alot of top end power.
Old Aug 20, 2002 | 10:56 AM
shortyz's Avatar
im in the same boat as u
Old Aug 20, 2002 | 07:29 PM
StorminMatt's Avatar
Default Re: what engine swap to do (shortyz)
If you are going to go through all the expense of buying a mount kit anyway, qhy not do a B20 rather than a B18A1? I guarantee you that if you rode in both, you would find that the B20 is worth every penny over the B18A1.
Old Aug 20, 2002 | 07:32 PM
EP3_05's Avatar
Why go b18a1 when you can have more torque with the b20. I would suggest doing the b20 swap.
Old Aug 20, 2002 | 08:56 PM
burnett999's Avatar
Default Re: what engine swap to do (91civic)
where is a good cheap place to get the b18 or the b20
Old Aug 20, 2002 | 09:05 PM
Mugen Dom's Avatar
save for a B16A
Old Aug 20, 2002 | 09:49 PM
*Boostwerks*'s Avatar
....in before the lock
Old Aug 21, 2002 | 12:30 PM
KrazyPRican's Avatar
Default Re: what engine swap to do (Bryson)
what swap is more reliable and less costly and will still do good with the 1/4 mi time? in other words how can i hit 12's and still have a reliable engine car and also a daily driver?
Old Aug 21, 2002 | 12:33 PM
ijjz's Avatar
Default Re: what engine swap to do (KrazyPRican)
id go b20
Old Aug 21, 2002 | 01:20 PM
slowman's Avatar
I took way too long
Default Re: what engine swap to do (beatdown88hf)
mini me... sohc power man!
Old Aug 21, 2002 | 01:37 PM
slowwrex's Avatar
Torque Baby!!!
Old Aug 21, 2002 | 02:31 PM
cr-x si's Avatar
Default Re: what engine swap to do (slowwrex)
You could get a zc for $500 then take the rest of your $$ and build it up. It'll run 12's if you put the right mods on it.
Old Aug 21, 2002 | 02:33 PM
spoonef's Avatar
sohc vtec motor=$400 depending on where you live but it should be cheap then a turbo kit im not sure what you would go for but after everything is done you might run high 13s depending on your setup
Old Aug 21, 2002 | 03:07 PM
big pete's Avatar
Default Re: what engine swap to do (jdmb18hatch)
save for a B16A
i second that
Old Aug 21, 2002 | 03:33 PM
speeddave's Avatar
Default Re: what engine swap to do (big pete)
i would say that b16a is not your best quarter mile performer, depends what car you have but your probably looking at mid 14's from a civic/crx. the b18a can be just as quick (i've seen it) but thats a whole other debate.
a b20 would have great torque, if you can find one for a good price. an ls/vtec or b20/vtec is what your gonna need to run 12's n/a imo.
Old Aug 21, 2002 | 03:42 PM
xXx Justin xXx's Avatar
cr-vtec
Old Aug 21, 2002 | 05:14 PM
AaronJ's Avatar
Default Re: what engine swap to do (chrisonepointsix)
if u want a fast quarte rmile sell your honda and by something rwd.
What?
Old Aug 23, 2002 | 09:04 AM
drunk's Avatar
Default Re: what engine swap to do (AaronJ)
rwd second that or get a 92 talon...tsi awd do a 16g turbo for less then a 1000...then fmic and the normal mods exhaust intake and runs 12's
Old Aug 23, 2002 | 09:15 AM
Home Skillet's Avatar
i've seen quite a few B16A's run 12's but they were built. I would suggest a crvtec for torque and high end power.
Old Aug 23, 2002 | 09:16 AM
marty's Avatar
as.dhflasyhgdfkiauwsyelrfijhs,kdhbjzhsgdflasywejkr fhaksjdfjshIwishpeoplewouldusethesearchbutton !!!skjdfkjashdjfhgasldhgflshdfljhsdjfhsd
Old Aug 23, 2002 | 09:25 AM
SuperCivic's Avatar
Default Re: what engine swap to do (MugenEF7)
be original..go F series yo!!!
TeamRPM_ZC
Apr 27, 2008 12:17 PM
Nipsey Hussle
Aug 6, 2005 07:18 AM
kaspur_eh
Apr 29, 2004 04:04 PM
