Wiring Harness/Plugs Help
Old Jun 9, 2009 | 06:49 PM
EKris's Avatar
Default Wiring Harness/Plugs Help
I just got done putting my B20 into my DC, but I am unsure where some of the plugs connect to. Is there a site or diagram + colors of the wires that I can look at so I can get all the plugs into the correct spots?
I am not sure on the color of the TPS, MAP Sensor, IACV, and there are some others that I can't remember from the top of my head.
Old Jun 9, 2009 | 09:49 PM
seanbev24's Avatar
Default Re: Wiring Harness/Plugs Help
Get a manual that has a wiring diagram, even hayne's will work. It will tell you what color wires go to each sensor. Once you've found the right ones, label each plug with a sharpie to make things easier in the future.
Old Jun 9, 2009 | 10:14 PM
EKris's Avatar
Yeah, I was unplugging things from the old motor, and was stupid and forgot to label everything. Thanks for the help though, I'll probably pick up a manual tomorrow.
chad olson
Jan 13, 2009 06:35 PM
turboblack2door
Jun 8, 2008 09:24 AM
this1drumma
Mar 5, 2008 02:07 PM
HidPerf
Sep 13, 2004 01:39 PM
Nid Styles
Feb 25, 2004 09:50 AM
