94 accord, won't shift out of park, messed with stereo wires...
Old Jun 9, 2009 | 04:09 PM
Ryan31's Avatar
New User
Default 94 accord, won't shift out of park, messed with stereo wires...
I just bought a 94 Accord, it drove fine home. It had no stereo, so I decided to put one in. The wires were cut, so I was trying them to figure out what did what....NOW the car won't shift out of park unless using the shift lock keyhole, and it uses one gear when in drive....second or third. It'll go into first if shifted to it, but won't use second when shifted to it. Brake lights work. HELP!!!
Old Jun 9, 2009 | 10:57 PM
evan221's Avatar
Default Re: 94 accord, won't shift out of park, messed with stereo wires...
fuse...
Old Jun 10, 2009 | 04:51 AM
Ryan31's Avatar
New User
I checked all fuses I could find. Brake light fuse was blown, that got the windows and sunroof working again.... I keep reading about "limp-home mode" and the brake light switch...
Old Jun 10, 2009 | 09:40 AM
tyronne1126's Avatar
Go to 12volt.com and find out the real use of each wire and redue the stereo.
Old Jun 10, 2009 | 10:32 AM
evan221's Avatar
i had the same prb when i was doing my euro brake light and i blew the fuse. all i did was changed the fuse and i was good to go.
i guess try to reset your ecu
Old Jun 12, 2009 | 04:02 AM
95EG690022's Avatar
check your cruise control fuse, i dont know how it all ties into one but i was messing with my car last time and my car wouldnt get out of park unless i used the shift lock keyhole. Looked at my fuses and found the cruise control blown, replaced it, car worked fine
Old Jun 24, 2009 | 04:52 PM
SparkyNZ's Avatar
New User
Icon2 Re: 94 accord, won't shift out of park, messed with stereo wires...
Hi, I have a similar problem. I found one night that I couldn't shift out of park and that the shift-lock solenoid was no longer making a noise. Rather than test it out properly, I disconnected the solenoid linkage. After putting the console all back together, I then found my cruise control was no longer working but my brake lights are.
Does the brake light switch have a seperate 'switch' or set of cables inside specifically for the cruise control, or is it a simple switch - ie. 2 wires only? My car is at home at the moment and I'm toying with the idea of going to an auto-electrician. I don't care about the shiftlock solenoid - I just want my cruise control back.
Thanks
Mario Locatelli
Sep 16, 2013 08:26 AM
bks84
17
Sep 19, 2011 06:40 AM
ryanhanson91ex
Oct 18, 2005 08:43 AM
MarkZeroNine
Jul 2, 2005 12:24 PM
redluder24
Aug 9, 2004 07:28 AM
