how to remove spot welds?
Old Jun 8, 2009 | 09:19 PM
avaldez's Avatar
Default how to remove spot welds?
Whats the best and easiest way to remove spot welds. I tried using a hammer and chisel but it was not going to well.
Old Jun 8, 2009 | 09:46 PM
Linh.'s Avatar
Default Re: how to remove spot welds?
Spot weld drill bit
Old Jun 8, 2009 | 10:31 PM
Anton LaVey's Avatar
this cant be a real question this is such a joke
Old Jun 8, 2009 | 10:55 PM
avaldez's Avatar
Originally Posted by Linh.
Spot weld drill bit
right after makin the thread i went out and bought a drill bit for metal. that should work you thing?
Old Jun 9, 2009 | 01:07 AM
MrParks's Avatar
you can drill the spot weld out completely or you can get a a sheet metal cutter set from snap on which i reccommened. it cuts my work time down by 70 % then driling out the whole weld. worth every penny. cost is about 120.00
Old Jun 9, 2009 | 05:00 AM
da_russian_one's Avatar
use one of these
http://www.machinemart.co.uk/images/.../040210467.jpg
or use a regular metal drill bit and CAREFULLY drill through the metal layer you want to REMOVE
Old Jun 9, 2009 | 08:54 AM
spiceisler's Avatar
Eastwood also sells them:
http://www.eastwood.com/catalogsearc...spot+weld+bits
Old Jun 9, 2009 | 01:33 PM
avaldez's Avatar
Thanks guys for all the help but I went by using a regular drill bit to remove them. Heres a link to some pictures.
https://honda-tech.com/forums/appearance-build-threads-122/ef-project-2585495/
Old Jun 10, 2009 | 05:47 PM
tepid1's Avatar
One of the best tools I've ever used. I expected it to be weak and wear fast so I bought extra bits.... well, I wasted money on the extra bits. lol. They last super long, but you need to take your time. I cut all the spot welds at a medium pace and the bit is still super sharp. I HIGHLY recommend this tool!!!!
http://cgi.ebay.com/Rotabroach-3-8-S...3A3%7C294%3A30
Old Jun 10, 2009 | 07:19 PM
srmofo's Avatar
rotobroach FTW....I couldnt believe how well they worked . I dont do a whole lot of body type work but what little I have done it has cut the tear apart time in half....I used to just use a unistep bit and drill through both panels , but of course that didnt always work out so well when reattaching things
Old Jun 10, 2009 | 07:33 PM
ToxicFabrication's Avatar
OG Fabricator
Originally Posted by da_russian_one
use one of these
i have one like this. works great. i used 3 blades which is really 6 to remove over 200 spot welds in the back of a 350Z to guy it for the cage. i love these things well worth the money
Old Jun 11, 2009 | 05:23 AM
daybreaksaint's Avatar
just get the drill bit
Old Jun 11, 2009 | 08:33 AM
98Luder's Avatar
hey i tried using those a spot weld removal bit with the retracting pilot and had terrible luck with it. I think maybe because mine was a cheap knockoff.
I just tried using one of my regular drill bits and it came out pretty easy.
I just center punched the spot weld and went to town
I'm not sure if this is the proper way to remove spot welds but it seemed to work for me
just sharing my experience since i just did this yesterday
Race Egr
Welding / Fabrication
27
Apr 20, 2005 01:05 AM
ekdriven
Mar 8, 2005 08:00 AM
ih8danoles
Apr 21, 2003 12:21 PM
MugenPoweredLude
Mar 17, 2003 04:53 AM
iam7head
Sep 25, 2002 07:05 AM
