sedan cluster in hatch?
Old Jun 8, 2009 | 05:57 PM
bluestd's Avatar
Default sedan cluster in hatch?
will a cluster from a 90 ef lx sedan work on a 90 std hatch? will it be pug and play? o and wats the red line on a d15b2 non v tec. need to know before i buy it thanks in advance
Old Jun 8, 2009 | 06:12 PM
bluestd's Avatar
Default Re: sedan cluster in hatch?
o and is the lx dx and ex cluster the same
Old Jun 8, 2009 | 09:56 PM
whitetoy's Avatar
It should swap over fine. If you have an AT, then make sure the donor
vehicle has an AT. Keep in mind that you will inherit the odometer
mileage, unless you swap your original odo unit into the new cluster.
This is what I did.
I have a 91 DX hatch with AT, and swapped a cluster from an LX sedan
for the tachometer. Swapping in the odo into the new cluster was a bit tricky.
Its all plastic, so it can be easy to break something.
Old Jun 8, 2009 | 11:02 PM
4gen5thtime's Avatar
I believe the lx and ex clusters are the same. Dx's had no tach. Si is also the same I believe. They are plug and play aslong as you get the right year combo.
Old Jun 9, 2009 | 10:35 AM
bluestd's Avatar
all right thanks for the help guys
Tank_EM2
Honda Civic (2001 - 2005)
Mar 14, 2014 01:02 PM
Slacker93eg
27
Apr 24, 2011 12:12 PM
Wuffer
Jul 30, 2007 05:14 PM
ham
Oct 23, 2004 08:03 PM
Speedfreak
Dec 11, 2002 04:43 PM
