MOTHER OF GARAGE CLEANUPS... pixxxx
make offers on everything. i will only meet in west palm beach not going any further. but i will ship and i do accept paypal.keep in mind paypal fees size of item being shipped and weight when making an offer. stuff im looking for possible trades are:lcas for integra,catch can setup,valve cover with or without bungs welded for b series, aftermarket half radiator, slim fan, obd1 vtec dizzy, aftermarket throttle body b series, aftermarket vacuum block, integra suspension bushing kit,steel braided brake lines teggy,jayandmeli@hotmail.com.......... i will be letting the pics do
the talking.
stock p72 rods and pistons
b series mounts,brackets,ls dizzy with msd cap for external coil look for coil in other pix,oil pump,slave cylinder
stock b series flywheel,good clutch,si cluster from del sol,crank pulley b series
b series mani,cam gears b series,hasport cable trans conv mount,
b series axles,shift linkage,half shafts
integra dual slim fal fans in perfect working order
alternator
single cam comp
xs bov and free wastegate just needs screws for top both work great
b series gasket set,ctr pistons with pins and rings all new,king std race bearings b16 bnib
airbox eg , p72 ecu
96-98 climate control
b series oil pan
b series starter
civic fan
shift linkage and ****
obd2b-obd1 jumper harness,misc light sockets
cruise control box
timing belt tens spring
intake with nos jet installed
fans radiators civic,
b series fuel rail
b series header
integra abs block
integra condenser and lines
b series
gsr main stud kit bnib
b series shift linkage
the talking.
alternator
single cam comp
airbox eg , p72 ecu
b series oil pan
b series starter
civic fan
cruise control box
b series fuel rail
b series header
integra abs block
b series
you guys thought that was it. noooo... i wasnt lying keep looking more pix...
integra
misc turbo piping
msd 6al and blaster coil
civic si climate control
eg center console
integra
misc turbo piping
eg center console
that price works i can say though shipping will be a little chunk. all three will be heavy. if i had to guess right now shipping would be around 27 bucks give or take.
