Test pipe+CEL elim=tight fit
Old Jun 8, 2009 | 02:00 PM
blkcivic99_03's Avatar
Default Test pipe+CEL elim=tight fit
The car is a 99 ex. I've been running a DC 4-2-1 and Apex WS2 for a few years now. A couple of months ago I started noticing a rattling sound (rocks in a can) that I thought was coming from my exhaust. I figured it had to be the cat since it had almost 200k on it. I went with the skunk2 test pipe and blox cel elim. The only problem is the top of the o2 sensor is now up against the bottom of the car and making a vibrating noise itself and the other rattling noise is still there too. i got a hammer and tried to make some extra room but the metal didnt give too much. Any ideas on how to make some more room for the 02 or what the noise might be?
Old Jun 8, 2009 | 02:12 PM
slow96lude's Avatar
Default Re: Test pipe+CEL elim=tight fit
heat it up with a torch then use a bigger hammer
Old Jun 11, 2009 | 07:17 PM
roc's Avatar
roc
buy an o2 bung $5, weld it onto the test pipe in a different location,repositon the o2 sensor
Old Jun 11, 2009 | 11:05 PM
jluo_hatchy's Avatar
the rattling mite be a vacum in the exhaust. if your running a stock exaust that would make sounds. you need the exhaust the flow more open and freely
mxracer420
Mar 25, 2010 04:33 PM
MADBADGER
Honda S2000
Oct 13, 2007 04:33 PM
Azn Kenny
Oct 11, 2005 05:14 PM
nullbert
Jul 11, 2002 11:02 AM
neo1z
May 25, 2002 03:02 PM
