overlooked parts for b swap
Old Jun 8, 2009 | 09:22 AM
dafuzzbudd's Avatar
Default overlooked parts for b swap
I finally have collected mostly everythnig i need to put a b series in my 96 ex
I need to make one final order from the dealership and want to make sure I won't need anything random once im in the middle of this.
i have
em1 t mount, b front tranny mount, crv front ac mount, em1 side post mount
ecu
1/2 shaft
b axles
header
linkage(buying)
throttle cable(buying)
I know i need
tranny bolts 95701-08040-08 x16(people said there's 2 lengths but i see one)
http://www.hondapartsunlimited.com/s...p=Transmission
1/2 shaft bolts 90102-SF1-000 x3
bitch pin 90751-S04-000
http://www.hondapartsunlimited.com/s...emcomp=Chassis
throttle body gasket 16176-P2T-004
oil
coolant
coolant main hoses i can pickup from advanced auto
M/T fluid
axle grease
are there c clips and bobbypin clips im going to need?
reuseable?
all mount bolts
fuel rail bolts
header bolts
linkage bolts
if you have experience please make sure i've covered everything. thanks!
Old Jun 8, 2009 | 09:45 AM
kyden's Avatar
Default Re: overlooked parts for b swap
radiator hoses.
Old Jun 8, 2009 | 10:20 PM
dafuzzbudd's Avatar
ohk, more.
Old Jun 9, 2009 | 11:32 AM
i2ishift's Avatar
what engine wiring harness are you planning on using? depending on your answer you may need a donor harness for connectors and ecu pin pigtails. you would also need extra wiring to extend o2 sensor. need more details....obd1 or obd2 Bseries?
Old Jun 9, 2009 | 11:50 AM
kyden's Avatar
those bolts you linked are for the transmission housing, not where it attaches to the engine. also.. clutch inspection cover? engine to transmission braces on the bottom?
tranny bolts are here.. #22, #40
http://www.hondapartsunlimited.com/s...o=%7C022%7C040
Old Jun 9, 2009 | 01:51 PM
dafuzzbudd's Avatar
alright thank you^ so there's only 3 bolts that hold it to the engine?
im going to take pics of the engine/tranny to make sure i have all the needed parts on it.
my d16y8 is obd2a and so is the b18b i have
from what i hear it's an easy wiring job that i shouldnt have any trouble with.
Old Jun 11, 2009 | 03:00 PM
LA_HONDAS's Avatar
tranny bolts are here.. you will need 2 #21, 3 #22 and 1 #41,#40
#40 is the small start bolt
the wiring harness will plug right up
Old Jun 12, 2009 | 09:28 AM
dafuzzbudd's Avatar
nice, alright.
and are there c clips and cotter pins i need for axles and castlenuts?
all mounts bolts are reuseable right?
i think that's about it.
Old Jun 12, 2009 | 10:28 AM
dafuzzbudd's Avatar
56997-P3F-000 CRV for pwr steering pump.
94201-20350 cotter clips
94201-30450 cotter clips
Old Jun 16, 2009 | 12:56 PM
dafuzzbudd's Avatar
any more?
Old Jun 21, 2009 | 12:07 AM
dafuzzbudd's Avatar
more plz
Old Jun 22, 2009 | 02:19 PM
dafuzzbudd's Avatar
bump
Old Jun 24, 2009 | 10:14 AM
dafuzzbudd's Avatar
are these the radiator hoses I need? Upper and Lower
19501-P72-000
19502-P72-000
Old Jun 26, 2009 | 08:35 AM
dafuzzbudd's Avatar
i just realized i need a pullley. the pulley is itself and 1 bolt?
and i overlooked the need for a starter.
Old Jun 26, 2009 | 08:36 AM
dafuzzbudd's Avatar
more pics
Old Jun 26, 2009 | 08:42 AM
LA_HONDAS's Avatar
yes thats hoses you need
Old Jun 26, 2009 | 09:21 AM
kyden's Avatar
get yourself the boot that covers the clutch fork.
Old Jun 27, 2009 | 07:26 AM
dafuzzbudd's Avatar
outside the tranny right? will my d-series work? :-)
the shifter attaches only by the pitch pin right?
does the clutch fork bolt on? hope my dseries bots will work :-)
when i bought the motor the guy said something was missing on the back of the block that i could take off my d16y8. something thermostat related, anyone see what im talking about?
Old Jun 27, 2009 | 12:19 PM
echoside's Avatar
The bolts holding your d series tranny to the d engine won't work for the b?
Old Jul 3, 2009 | 10:58 AM
dafuzzbudd's Avatar
i read somewhere that b-series uses a couple different size bolts, onle 2 of the d's would work. id rather be safe and rebuy them all.
crank pulley bolt - 90017-PR3-003
process of buying starter and pulley.
can i go without the inspection plate? they seem to be impossible to find.
Old Oct 30, 2009 | 12:01 AM
dafuzzbudd's Avatar
after much delay parts all ordered
bought an act clutch, fidanza wheel. passing on the power steering.
all i need is throttle cable i think.
how necessary is the inspection plate? where can i find one?
Old Oct 30, 2009 | 05:02 AM
kyden's Avatar
dealership? or maybe someone has one lying around?
21351-PR3-010 1 COVER, CLUTCH CASE
Old Oct 30, 2009 | 06:23 AM
dafuzzbudd's Avatar
thank you for that part number
Old Jun 27, 2010 | 08:04 AM
typerex91's Avatar
if i have a gsr trans, would it matter if i got that plate for a gsr or an ls?
Old Jul 27, 2010 | 11:12 PM
tn_civic's Avatar
you should get some maintenance stuff done while you have the motor out:
timing belt
ac belt
alternator belt
power steering belt (if it applies)
water pump
valve cover gasket
axle seals
the hand of god
Mar 1, 2010 03:05 PM
Nfire247
Jan 14, 2008 12:15 PM
Diaz90
Dec 5, 2007 08:49 PM
the1337aaron
Apr 12, 2006 10:17 AM
slow_civic
Nov 12, 2001 06:51 PM
