oem oil cooler rubber gasket
From: fountain inn, sc. where they still rock banjos on porches, usa
well i have a DOHC ZC newly rebuild engine and i'm having a hard time looking for a gasket for my oil cooler can some know if a 88-89 integra oem oil cooler will work cause it's leaking from there and only there. it's #24:
Probably be the same as any other honda (accords & b-series also have them), or take it to an industrial/commercial shop and get an O-ring the same size. You can even pull one off an oil filter, IIRC.
i did i found the specs off the 89 acura integra oil cooler(91316-PE7-730 O-RING (62.4X3.1)) and went to the auto store and match one with a coolant o ring. so i'm cool now. it was $1.99
B16CivicEX
May 30, 2006 03:15 PM
