Transmission & Drivetrain Gearboxes, Differentials, Clutches
master/slave procedure
Old Jun 8, 2009 | 01:08 AM
prjctsilverknighty2k's Avatar
Default master/slave procedure
does anyone have the procedure for changing out the master and slave cylinder? my clutch pedal is currently chillin on the floor.
Thanks in advance
Old Jun 8, 2009 | 04:56 AM
BlakeJ53's Avatar
Default Re: master/slave procedure
Before you do any of this check and see if you just need more fluid. You use Dot 3 brake fluid. Then bleed it like you bleed a brake. Drain fluid. Undo the clutch line with a 10mm LINE WRENCH. Remove 2 10mm and 2 12mm bolts. Remove pin from clutch pedal. Replace with new parts, bleed clutch. Thats the jist of it. Just get in your car and look its pretty basic stuff. Good Luck
Old Jun 8, 2009 | 10:47 AM
i already checked the fluid. its good.
97tegGS
Feb 24, 2017 01:24 PM
JoshV1288
19
Jan 26, 2013 02:41 AM
JusAccord
Nov 7, 2011 05:51 PM
07FG2
Honda Civic (2006 - 2015)
11
Jan 10, 2009 02:11 PM
gsr1289
Aug 22, 2006 07:11 PM
