which coilover has the best ride?
Old Aug 20, 2002 | 07:56 AM
newciv's Avatar
Default which coilover has the best ride?
Trying to decide which coilover i should purchase. My biggest concern is ride quality. The local shop recommened ground control but they also have skunk2 and some others . i want to know the good and the bad , oh this is also my first post .
[Modified by newciv, 4:58 PM 8/20/2002]
Old Aug 20, 2002 | 08:04 AM
kay_animation's Avatar
Default Re: which coilover has the best ride? (newciv)
When i was picking coilovers, my top two choices were ground control and skunk 2 too. I went with ground control. Their supposed to be a much better ride. Right now i'm looking for shocks/struts because everyone says the stock ones will blow with aftermarket coilovers. I suggest ground control. When I get the shocks/struts, i'll put em all on. If you wanted to know, I hear KYB AGX and Tokico shocks are really good. Hope that helped.
Old Aug 20, 2002 | 08:43 AM
Archidictus's Avatar
Unceasing Measure
save $1,000 and get Tein's
Old Aug 20, 2002 | 08:56 AM
vivid02's Avatar
I had skunk2 coilovers and they were pretty stiff. I prefer the GC though. They almost feel the same.
Old Aug 20, 2002 | 10:41 AM
esoterEK..'s Avatar
i prefer GC because the hardware they give u is complete and better than skunk..abut ride characteristics u cant really tel the difference.....between thems...unless u buy some aftermarket shocks and match it wit ur spring..rate....maybe that might help.........
Old Aug 20, 2002 | 10:46 AM
dphi's Avatar
Call up Ground Control and let them know what you're looking for. They'll do custom spring rates if you want.
Old Aug 20, 2002 | 11:12 AM
W.Zero's Avatar
Default Re: which coilover has the best ride? (vivid02)
never do they feel the same. skunk2 are alot more stiff then GC. get GC, there the best for everything. if you want it for drag, road, show, etc etc.
Old Aug 20, 2002 | 11:48 AM
drvfast's Avatar
Default Re: which coilover has the best ride? (Archidictus)
yep
Old Aug 20, 2002 | 12:32 PM
9d9GSR's Avatar
Default Re: which coilover has the best ride? (drvfast)
my neuspseed coils have a good ride. no bounce
Old Aug 20, 2002 | 12:43 PM
Yesman's Avatar
New User
Default Re: which coilover has the best ride? (9d9GSR)
my GC squeek.
im looking into a set of Zeal or Tien's.
Old Aug 20, 2002 | 01:03 PM
96 SOHC VTEC's Avatar
Default Re: which coilover has the best ride? (bishop)
my GC squeek.
Have you tried cleaning them, or spraying some lubricant on them?
Old Aug 20, 2002 | 01:05 PM
Yesman's Avatar
New User
Default Re: which coilover has the best ride? (96 SOHC VTEC)
yes and i've changed out the bushings and checked the motor mounts etc...called GC but they couldnt figure it out.
Old Aug 20, 2002 | 01:48 PM
bullz's Avatar
Get a complete damper system. You'll be happier overall.
Old Aug 21, 2002 | 07:21 AM
BigDaddyRich's Avatar
Default Re: which coilover has the best ride? (iLLestjr)
Coilover sleeves are GHEY. you still have a strut/shock and a independent spring. Complete systems with adjustable height and dampening cant be beat. Companies like JIC, Tanabe and H&R make pretty good setups
Old Aug 21, 2002 | 07:26 AM
Captain Save-a-Hoe's Avatar
Default Re: which coilover has the best ride? (BigDaddyRich)
I hate you guys, you make me wanna spend more $$$$. Now I want a full coilover for my hatch.
Old Aug 21, 2002 | 07:33 AM
Eternity's Avatar
tein
Old Aug 21, 2002 | 07:50 AM
TruePlayaz114's Avatar
Default Re: which coilover has the best ride? (Eternity)
what is the best full coilover?
Old Aug 21, 2002 | 11:54 AM
MR. ARIZONA's Avatar
Default Re: which coilover has the best ride? (TruePlayaz114)
TEIN duh!!!
Old Aug 21, 2002 | 02:39 PM
newciv's Avatar
doesss anyone have any experience with " red suspension" i seen a ad in super street for 399 for coilovers i wonder how good a product they are?
Old Aug 21, 2002 | 05:18 PM
01gizzer's Avatar
NEX all the way
Old Aug 21, 2002 | 05:34 PM
Civicboy's Avatar
Default Re: which coilover has the best ride? (QUICKTEG)
TEIN duh!!!
I agree and Teins aren't that much more than GCs and Koni adj. check out http://www.machiii.net/machiii/html/...tein/tein.html
[Modified by Civicboy, 6:36 PM 8/21/2002]
Old Aug 22, 2002 | 05:23 PM
Default Re: which coilover has the best ride? (Civicboy)
I have TEIN HA's on my IS300 and the dam rear rattles too much. Everyone I know with tein gets a little rattle. I suggest Tanabe Sustec SS. I heard they are good too.
skynyrd006
Jun 12, 2006 05:00 PM
JMod
Sep 13, 2003 06:23 AM
MrJasey
Jun 22, 2003 04:13 PM
VTECTIME
50
Oct 25, 2002 03:39 PM
