FS:2.0 B18C fully built, no details missed, boost monster 0 miles
Old Jun 7, 2009 | 09:16 PM
PYDB8-R's Avatar
Icon3 FS:2.0 B18C fully built, no details missed, boost monster 0 miles
decided to finish car
Old Jun 7, 2009 | 09:24 PM
91efsikevs's Avatar
Default Re: FS:2.0 B18C fully built, no details missed, boost monster 0 miles
How much for everything??
Old Jun 7, 2009 | 09:38 PM
PYDB8-R's Avatar
Make a realistic offer, it's listed for 6900 all together, also have a fuel system for the setup too for those interested.
Old Jun 11, 2009 | 10:25 AM
PYDB8-R's Avatar
100 views and 1 bump, wow.
Old Jun 11, 2009 | 10:48 AM
dacuslil's Avatar
bump
Old Jun 11, 2009 | 01:51 PM
Navy_CRX's Avatar
Pics
Old Jun 11, 2009 | 01:57 PM
boostdc211's Avatar
picsss fasho
Old Jun 11, 2009 | 04:21 PM
PYDB8-R's Avatar
it looks like a motor, http://hondamarketplace.com/showthread.php?t=2582583
Old Jun 11, 2009 | 04:49 PM
gsreg94's Avatar
bump.. i want it
Old Jun 11, 2009 | 08:10 PM
PYDB8-R's Avatar
bump
Old Jun 12, 2009 | 06:06 AM
RyosukeFC3s's Avatar
Willing to part anything? (i.e. the wastegate and BOV?)
Old Jun 12, 2009 | 07:43 AM
to4e hatch's Avatar
bump
Old Jun 12, 2009 | 09:56 AM
slowboyy06's Avatar
Originally Posted by PYDB8-R
Motor was intended for my DB8 project but everything must now go. 0 miles since build. Motor was built by Dave at Basham Motor Sports. Selling as a long block for now. Do not lowball me, be realistic with OBO offers as my prices are already reasonable. Please don't waste my time or yours. If you're serious with cash in hand you can reach me at 909-810-3473, name is Nick. Also selling the turbo kit. Please bump if viewing. Thank you.
Asking $4500 obo for longblock
HEAD
-ITR head
-combustiom chambers opened to 84mm and fully blended
-KG Engine Builders turbo ported
-T1 catchcan and vented valve cover, all black except can and filters
-CTR cams
-Skunk2 pro series cam gears
-Skunk2 daul valve springs
-Skunk2 titanium retainers
-Skunk2 70mm portmatched throttle body
-OMNI 3bar map
-Blox new TPS
-all sensors and vtec solenoid
-OEM dizzy
-MSD cap
-MSD wires
-MSD MSD coil
-1mm oversize stainless valves
-3 angle valve job
-all new OEM seals
-Edelbrock Victor X manifold, portmatched
-RS Machine thermal gaskets on IM and TB
-RS Machine cam seal
-Datum1 black fuel rail
-Precision 1000cc injectors
BLOCK
-JDM B18C block
-RS Machines open deck sleeves
-RS Machines 84mm bored OEM p30 head gasket
-Energy Dynamics EnDyn 84mm rollerwave pistons, fully coated dome and skirt
-Eagle 89mm crank, OD'd to clear oil squirters and balanced
-Eagle LS rods w/ARP big bolts
-All oem Honda Bearings
-Apocalypse Power modified OEM oil pump
-All new OEM seals
-new OEM oil pickup
-new OEM water pump
-Moroso 5.5 quart steel pan
-Moroso pan studs
-Golden Eagle head studs
-Golden Eagle main studs
-Power timing belt
Asking 2400 obo for turbo kit
TURBO KIT
-Ceramic coated in and out BLOX manifold, new
-T3/T66 ceramic coated turbo, 5 bolt, 0 miles new
-Downpipe Custom pie cut, tig welded, ceramic coated, ac friendly, 3" with wastegate tied in, flex pipe
behind oil pan, 3" vband for exhaust, 1 o2 bung in stock location, 0 miles new
-Synapse Syncronic 40mm wastegate w/pie cut 90' elbow off manifold, new
-Synapse Syncronic bov, new
-Apexi intercooler
-2.5" steel intercooler piping, gloss black
-most all couplers and t-bolt clamps
-Function7 oil return plate
--10 stainless return
-oil feed line
-push connect 1/4" fittings for vacuum hose
how far you away from boston some idiot just broke in my garage and stole my k build i need a block and dont have time for square one build and how much do think this setup was suppose to make i come this weekend to come get if the numbers is right (power and price)
Old Jun 12, 2009 | 02:27 PM
JDMInteg96's Avatar
ttt
Old Jun 12, 2009 | 09:38 PM
PYDB8-R's Avatar
bump
Old Jun 13, 2009 | 09:45 PM
PYDB8-R's Avatar
bump
Old Jun 14, 2009 | 08:56 PM
PYDB8-R's Avatar
bump
Old Jun 15, 2009 | 03:16 PM
PYDB8-R's Avatar
bump
Old Jun 15, 2009 | 09:48 PM
PYDB8-R's Avatar
bump
Old Jun 17, 2009 | 09:04 AM
PYDB8-R's Avatar
bump
Old Jun 17, 2009 | 03:54 PM
PYDB8-R's Avatar
bump
Old Jun 18, 2009 | 05:39 AM
TheWhopper's Avatar
this is a hardcore motor...hopefully someone here can afford it...good price for all the upgrades.
bump
Old Jun 18, 2009 | 09:53 PM
PYDB8-R's Avatar
thank you, bump
Old Jun 21, 2009 | 09:17 PM
PYDB8-R's Avatar
bump
Old Jun 22, 2009 | 05:36 PM
CRXB18C1_ALL MOTOR's Avatar
Are you willing to let everything go for $5500.00 cash picked up? Let me know.
