turbo tunning in two days.. missing anything??
hello everyone, I have just finished installing my turbo set up and I would like to hear if I have missed any items before I get tunned? I have another bottom end which will be built at a later time. I also plan on building the head as well. I realize I will only be able to boost about 8 to 10 pounds safely. I will be buying a up graded hondata map sensor for more boost. Any suggestions would be great. Please remember the motor will be built at a later date! Thanks!
MY set up
1) GSR MOTOR and LS tranny in EG SI
2) Full Race Pro Am Top mount manifold
3) t4 Turbonetics turbo
4) Spearco IC
5) 2.5 piping
6) 3 inch down pipe and 3 inch straight back without cat, muffler Vibrate 3 inch
7) Greddy RS BOV
8) Victor X intake manifold
9) RC 550 injectors
10) AEM fuel rail and fuel regulator
11) Hondata S300 (p28) obd1
12) NGK spark plugs
13) MSD 6al, external coil ss, new cap and rotor
14) Fuildene raditor
15) 12 inch slim fan
16) New timing belt, water pumper and type R oil pump
17) Morsoso oil pan tapped for turbo oil line, oil line sandwich adapter for oil return line
18) Greddy turbo timer (not necessary)
19) greddy Profec boost controller
20) DC short shifter
21) Clutch MAster stage 3 clutch and fly wheel
22) Hasport mount all 3
23) Walbro 255 fuel pump
24) 2 layered screen filter for turbo
25) Tial 44m wastegate
26) Prosport gauges (Boost, Water temp, Oil temp)
MY set up
4) Spearco IC
5) 2.5 piping
7) Greddy RS BOV
9) RC 550 injectors
12) NGK spark plugs
Sounds like you have everything.
Make sure your couplers are tight.
Make sure your not throwing any codes such as intake air temperature, cyp etc...
* Oxygen Sensor Bung: You must have a oxygen sensor bung which is accessable & installed in a proper location to where a good air/fuel pickup can be achieved. The oxygen sensor bung MUST have clean threads & be clear of any welds which may stop a larger wideband oxygen sensor from being installed into the bung.
* Electrical issues: Please resolve all electrical issues before tuning.
* Brakes, Suspension, Tires: All of these components are extremely important, especially if your going to have your vehicle street tuned. Please make sure they are all in good condition.
* Proper octane fuel for your application: Please inform your tuner of what fuel you are running. You should run the highest octane which is widely available in your area such as 93 octane. Try to prevent having your vehicle tuned with gas which has been sitting in your vehicle for more than 20-30 days.
* Forced Induction vehicles should invest into a pcv catch can system such as the endyne kit.
looks like you have everything but you can probably get away with more than 8-10lbs. I am running 14 on a stock GSR with an intake manifold. BUT YOU MIGHT WANT TO CHECK WHAT WASTEGATE SPRING IS IN IT!!! That could cause you a huge problem! But the car looks good under the hood
Checking the wastegate is a great idea! Turns out that the spring that I order 8pounds turned out to be larger! I ended up with 315 HP and 215tq. Very happy! Thanks for your guys help!
itr909
Jun 15, 2009 05:59 PM
slrh22hatch
Nov 18, 2004 03:45 PM
hondaboy65
Nov 9, 2004 04:39 PM
