finished turbo install small amount of water in TB??
Finished my turbo set up and found a small amount of water in the throttle body. Could this be a bad throttle body gasket? Any info would really help. thanks and heres my set up.
1) GSR MOTOR and LS tranny in EG SI
2) Full Race Pro Am Top mount manifold
3) t4 Turbonetics turbo
4) Spearco IC
5) 2.5 piping
6) 3 inch down pipe and 3 inch straight back without cat, muffler Vibrate 3 inch
7) Greddy RS BOV
8) Victor X intake manifold
9) RC 550 injectors
10) AEM fuel rail and fuel regulator
11) Hondata S300 (p28) obd1
12) NGK spark plugs
13) MSD 6al, external coil ss, new cap and rotor
14) Fuildene raditor
15) 12 inch slim fan
16) New timing belt, water pumper and type R oil pump
17) Morsoso oil pan tapped for turbo oil line, oil line sandwich adapter for oil return line
18) Greddy turbo timer (not necessary)
19) greddy Profec boost controller
20) DC short shifter
21) Clutch MAster stage 3 clutch and fly wheel
22) Hasport mount all 3
23) Walbro 255 fuel pump
24) 2 layered screen filter for turbo
25) Tial 44m wastegate
26) Prosport gauges (Boost, Water temp, Oil temp)
4) Spearco IC
5) 2.5 piping
7) Greddy RS BOV
9) RC 550 injectors
12) NGK spark plugs
Re: finished turbo install small amount of water in TB??
was it water? coolant? was it in your IM also? was it in your IC piping?
need a little more details. You gave us great details on the parts list, but need more about the issue itself.
almostboostedgsr
02-13-2007 12:37 PM
bluesiTYPER
06-14-2003 04:39 PM
