Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Towing Questions
Old Jun 7, 2009 | 06:05 PM
JRandolph's Avatar
New User
Icon2 Towing Questions
Hey everybody...new here to the site, I have a 2007 Honda Odyssey, with the towing package. I have a pop-up camper, weighing about 1800 pounds dry, about 2800-3000 pounds loaded. My question for you is, do you think a weigh distributing hitch is necessary or a electric brakes on the camper is needed. Also, how does the warranty work with this type of situation also. Thanks for all your help.
Old Jun 7, 2009 | 09:50 PM
Splaturn's Avatar
Default Re: Towing Questions
You'll be fine towing it, max trailer weight is 3500lbs. If you're going to be doing a lot of towing, you may look into a beefy oil and tranny cooler as well. You shouldn't need to worry about a weight distributing hitch, though it wouldn't hurt.
As for trailer brakes, you can do electronic brakes which works based on angles (dives = electronic brakes applied) or various brake controllers. Check your local ordinances as certain weights require one or the other, depending on local statutes and vehicle codes, based on the weight.
With warranty, if something goes wrong, they'll have to prove that you were improperly towing, and that's what caused the damages. Or that there was gross negligence involved somehow, whether it's driver error, or improper installation.
Good luck, and happy towing!
Old Jun 8, 2009 | 09:43 AM
Ross 2.0's Avatar
In a Junkyard near you.
If it's the Honda towing package it comes with power steering and transmission coolers. Even an air duct for them. If you are towing without the coolers you will not have a transmission warranty if there is a failure due to towing.
With a popup camper I would definately recommend using trailer brakes.
techin
Suspension & Brakes
Aug 19, 2009 04:20 PM
sony224422
Dec 24, 2005 08:29 PM
goforbroke
Jul 3, 2004 06:54 PM
deviant1
May 23, 2003 10:10 AM
