Need help on ignition timming
Old Jun 7, 2009 | 04:59 PM
johnny090881's Avatar
Default Need help on ignition timming
Ok I've got a 96 civic and I been having trouble starting the car at times. Theirs times when the engine will just rotate but won't start but once I get it on it runs fine, no lag or hesitation. Also once it's warm it starts kind of funny, do you guys think it's the timing?
Old Jun 7, 2009 | 07:39 PM
b16_sol_707's Avatar
Default Re: Need help on ignition timming
No, but it wouldn't hurt to check it. When is the last time you changed the cap, rotor, plugs and wires?
Old Jun 7, 2009 | 07:46 PM
tkda's Avatar
id say its a fuel problem.
you need to check for fuel and spark and timing then let us know what you found.
Old Jun 7, 2009 | 10:56 PM
Fo who, complete tune up hasbeen done cap rotor plugs wires fuel injectors water pump timing belt fuel filter fuel pump and the only thing I didn't downen I put the waterpumpand tb was tdc but nothing was moved car doesn't hesitate and lag power but then again it started acting up just a couple days ago with the cold starting.
bouncing87souls
Dec 22, 2010 09:04 PM
plantmylotus
10
Oct 14, 2008 10:49 AM
AllMotor12s
Nov 11, 2007 04:20 PM
bluelude2.3
May 25, 2007 11:58 AM
civicspeed77
May 27, 2003 12:13 PM
