i need help ASAP jdm d15b swap
okay so i got a 96+ jdm d15b dual vtec
now ima be swapping it on my 92-95 hatchy SI
what do i need to do for it to work
switch over manifold or just injectors ??
and how should i wire the two vtec solenoids ??(i have a p28)
im a little lost on this swap hehe
any help would be grateful
im only swapping because one of my rods made a big *** hole on my block lol :[
Re: i need help ASAP jdm d15b swap
lol hatchy is a hatchback for ex sample bubblehatch, eg and soo on... and what im trying to say is what do i need to do to put a jdm d15b OBD2 motor into my OBD1 civic si/ex. should i switch manifolds or just fuel injectors and how should i wire the two vtec solenoids
why do u think u need to change manifolds and inj.?
My brother just did this swap on his 98 Civic EX. The only way to get the Dual Stage VTEC to function the way Honda intended is to get the JDM ECU for the car. Otherwise, if you are running a P28, the engine will be in either 12 valve non VTEC mode or 16 valve VTEC mode. If I were you I'd just run the car OBD II with the JDM ECU because then you don't have to run the car improperly nor swap injectors or distributor. In order to make the Dual Stage VTEC in that case work, all you would need to do would be to run a wire from the second solenoid to the correct pin on the ECU. Don't forget to run high test in the JDM engine because it is a higher compression engine. Good luck.
i would like to do* that in the future but right now i need to get my car running asap.
how do i get it to run in 16 valve VTEC mode for now ?? just hook up my p28 and use the solenoid that has the green and yellow wire?
and my dizzy didnt fit so i think ima have to re-pin the obd2 dizzy??
what do i need to do for it to work switch over manifold or just injectors and how should i wire the two vtec solenoids ??(i have a p28)
im a little lost on this swap hehe any help would be grateful im only swapping because one of my rods made a big *** hole on my block lol :[
Seagull Management
Yep. I can understand swapping in an OBD1 D15B Vtec to replace a blown Z6, nice simple direct swap. But the OBD2 3 stage D15B Vtecs are pain in the *** unless you have the corresponding ECU.
Just swap the Dual Stage VTEC solenoid for a USDM D16Y8 or D16Z6 VTEC solenoid and run the P28 ECU. From what I understand, the engine will run in 12 valve non-VTEC mode until you reach VTEC in which the engine will run 16 valve VTEC mode. Someone correct me if I'm wrong.
I'm wondering thee same thing - swapped my d16y8 with a d15b obd2 into my 97 civic. Only reason I changed motors was b/c it was damn near impossible to find a low mileage d16y8 around here....
your idle should be normal if you use the y8 ecu your gonna be running 12 valves and then once you hit vtec your gonna run 16v vtec if you wire it to the solenoid with the green and yellow wire. if you wire it to the redish one your gonna run 12valves and then 16 valves non v its weird how it works if you want it to work right your gonna need the right ecu for it
I have this running in my 97 EX with a P2P ECU but it's stuck in 12v till 5500K where 16v VTEC hits. I know I should run the JDM ECU but it's impossible to find so in the mean time I'm going to be running a VAFC2 to switch 12v to 16v at 3500K. I hope it works... SO the red wire is the 12v to 16v solenoid?
twentyhurtz
09-16-2009 08:36 AM
