Manifold fabbers check in
Old Jun 7, 2009 | 02:13 PM
Linh.'s Avatar
Default Manifold fabbers check in
Im doing a rbc intake manifold on my h22 swap. The manifold doesnt have a place to mount the iacv. So I was thinking of just making a plate and having it welded to the manifold. Does it matter where I put the plate and drill the hole for the iacv? I wanted to weld it at the bottom of the manifold so that isnt visible. Im guessing it wouldnt matter but I just want to make sure.
Old Jun 7, 2009 | 03:18 PM
weiRtech's Avatar
OG Fabricator
Default Re: Manifold fabbers check in
i can't imagine the location being that critical.
Old Jun 7, 2009 | 03:27 PM
redzcstandardhatch's Avatar
something different
i made a plate that bolts to the IACV, and has two ports on it. one port is connected pre-throttle body , and another is post-throttle body.
if you look at an IACV setup on an intake manifold, one side of the iacv takes air from before the throttle body, and lets it into the manifold.
Old Jun 7, 2009 | 03:38 PM
redboost10's Avatar
just thought id post this here, just in case it would work for you.
http://www.t1raceparts.com/product_p/t1%20tm%20iac.htm
Old Jun 7, 2009 | 04:11 PM
Linh.'s Avatar
This sounds like a good idea. No need for welding but on the stock h22 manifold the iacv is mounted in the front. I cant really tell if its taking air from before the manifold. Ill probaly have to open the manifold and look. Do you have any pictures of your setup?
And thanks. I already made a plate if need to Ill make another one.
Old Jun 7, 2009 | 11:56 PM
honduh_head's Avatar
wait.... k series intake on a h head? dont mean to sound like a noob, but is this really possible?
Old Jun 8, 2009 | 05:07 AM
Linh.'s Avatar
Yes it is.
Im going to buy a karcepts intake manifold adapter with the ports. I just have to figure out how to take air from the throttle body..
Old Jun 8, 2009 | 05:32 AM
EGHATCH4YA209's Avatar
Karcepts manifold adapter? You mean QSD manifold adapter?
Old Jun 8, 2009 | 03:30 PM
Linh.'s Avatar
Sorry, I meant karcepts spacer. So I can hook up the iacv properly.
Old Jun 8, 2009 | 05:13 PM
so is there a benefit to this over say, a skunk pro intake or a edelbrock?
Old Jun 10, 2009 | 01:51 AM
AM_H2B's Avatar
QSD has an adaptor plate for the RBC manifold to the H22. Not sure if they are selling them, but you should try giving them a call.
Old Jun 11, 2009 | 09:07 AM
PM me for more info on the adapters, i just finished up my manifold yesterday.
Old Jun 12, 2009 | 05:53 AM
m R g S r's Avatar
holy **** that throttle body is hugeeeeee
Old Jun 13, 2009 | 03:11 PM
AndyGarcia's Avatar
New User
I was also going to go that route. Make a plate, drill the right holes and then weld it on. The only thing I worried about was if the plate were to warp and I would end up with a vacuum leak. I usually build everything but this was something I didn't want to hassle with. I ended up using a remote mount for the IACV. A simple machined block similar to T1 but made by AFI. Super simple: Weld a tapped bung on the charge pipe (before the throttle) and one on the intake plenum (after the throttle), mount your block somewhere you are satisfied, thread in all your fittings and route your lines where they go. And you're done. You're right about hiding the IACV, it does look clean. I made this intake with three ports on the bottom. (Left to Right pictured) Vacuum block source, Air intake temp, and the IACV. I strongly recommend this, but in the end it's your choice. Good luck, hoped this helped
Old Jun 13, 2009 | 03:37 PM
Linh.'s Avatar
Thanks for the picture. I made one last week.
Old Jun 15, 2009 | 12:48 PM
Cant wait to see your set-up
Old Jun 15, 2009 | 04:10 PM
Linh.'s Avatar
check it out in the other thread. Its nothing nice as yours haha
Old Jun 17, 2009 | 04:32 PM
peiku's Avatar
my buddy made this one for me.
Old Jun 18, 2009 | 03:34 PM
got wide's Avatar
do you know what the rough dimensions of that block are? L x W x H. or a link to where you purchased it?
Old Jun 18, 2009 | 03:58 PM
Linh.'s Avatar
Its really not that hard. You can make it to whatever dimensions you want it to be. Just lay out the iacv mounting holes and the inlet holes for the iacv. Then decide how you want to mount it. Anyways its looks like a 2x3 and 1/2 thick.
Old Jun 19, 2009 | 10:25 AM
got wide's Avatar
yeah i just wanted to order the aluminum before i took the iacv off. but yeah thats about what size i was guessing at exept about 3/4 thick, but i have to order the material by the foot so if anyone is interested i should have enough to make 2 or 3 extra if any one wants one made?
BlackCivicEX
May 24, 2011 11:39 AM
gezzuzz
Apr 13, 2008 07:40 PM
StolenTeg
Jan 13, 2007 08:18 AM
slomofo
Jun 8, 2005 05:14 PM
queez
Dec 9, 2003 09:41 AM
