DRL Light is on unless i turn on the headlights
Old Jun 7, 2009 | 11:14 AM
zann121's Avatar
New User
Default DRL Light is on unless i turn on the headlights
A couple of days ago my cluster went dead but after i changed the fuse it started working again. but now the DRL light stays on unless i turn on the headlights. why is that?
Old Jun 7, 2009 | 12:16 PM
Conflicted's Avatar
Default Re: DRL Light is on unless i turn on the headlights
I'd guess that your daytime running lights are off so the warning light turns on. Just a shot in the dark.
Old Jun 7, 2009 | 12:39 PM
TheMuffinMan's Avatar
He knows where you live!
Stay on if the car is off? Or stay on until the headlights go on while driving? They are supposed to be on all the time unless your headlights are turned on..........
DRL = Daytime Running Lights
Old Jun 7, 2009 | 07:40 PM
notAdiesel's Avatar
did you check the fuse for them? (the DRL)
Old Jun 8, 2009 | 03:29 AM
zann121's Avatar
New User
Yes, i just checked. but the fuse looks perfectly fine. This just happened after i replaced the fuse for my cluster because it stopped working. usually the Daytime lights stay on always unless i turn on the headlights. but now it doesnt work at all.
Old Jun 8, 2009 | 03:39 AM
GhostAccord's Avatar
OK what is the current issue with your car? in your first post your talking about the DRL indicator on the dash being on when your DRL are on. Now your saying that your DRL don't work. What one is it?
Old Jun 8, 2009 | 05:14 AM
zann121's Avatar
New User
my DRL indicator stays on in the dash when my headlights are off. in order for the DRL indicator to turn off on the dash is for me to turn on my headlights.
Old Jun 8, 2009 | 06:23 AM
OK so when your DRL indicator light is on are your daytime running lights also on when you look at your car from the front? If they aren't on when the DRL indicator is lit. Check the under dash relay/fuse box, fuse No.10 7.5A (Day Lights) is what your looking for.
The DRL indicator light on your dash and the dim low beam lights are both supposed to be on any time that you have your driving (nighttime) headlights switched off.
Old Jun 11, 2009 | 04:25 PM
zann121's Avatar
New User
I checked all my fuses. I think my module is burnt. I checked both "DAY TIME" fuses on both fuse boxes but it doesnt seem to solve the problem. When i used to drive daytime i usually see 2 lights working on the front but it stopped working now
Old Jun 11, 2009 | 06:03 PM
lx93cb7's Avatar
New User
dont know if its the but just a thought because it happened to my friends car , but anyways , all the wiring had shorted out and melted all the wires
Old Jun 11, 2009 | 06:28 PM
OK try this then I remembered seeing this a few years back and this may or may not help you out.
Here is a link
DRL Relay Fix DIY
Old Mar 28, 2015 | 02:58 PM
mainshahwan's Avatar
Old Mar 28, 2015 | 03:12 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Originally Posted by mainshahwan
_______
1.What issue do you have?
2. What year and model?
3. Refer to the link in post #11 if your DRL doesn't work.
Old Aug 23, 2015 | 08:29 AM
FrankR's Avatar
Same issue. Result was burned out headlight terminal in firewall
Old Aug 23, 2015 | 02:29 PM
What do you mean by terminal? Are you referring to the relay or a wire harness connector?
Old Aug 23, 2015 | 03:10 PM
FrankR's Avatar
Wiring harness
Old Mar 21, 2016 | 10:15 AM
Patrizia Hall's Avatar
Old Mar 21, 2016 | 10:19 AM
After much research on this issue with my 1999 Odyssey, I found that the DRL relay switch is faulty and needs to be replaced. It is located behind the glove box. I could not find a replacement on ebay or Amazon but found a brand new one with a company in New Jersey. I hope this helps.
Fincivic
Jul 1, 2017 10:59 PM
gingerheadman
Honda Civic (2001 - 2005)
Jun 20, 2012 04:56 PM
patrickstar
Apr 23, 2009 10:28 PM
drumminforev
Aug 9, 2006 07:34 PM
Bserieskllr
12
Aug 1, 2004 01:38 PM
