96 civic hatch d14 CEL 16 "injectors" Help Needed
Old Jun 7, 2009 | 07:08 AM
delsol1's Avatar
New User
Icon6 96 civic hatch d14 CEL 16 "injectors" Help Needed
Hi all. I posted a thread in here before Christmas and I still haven't been able to sort this car. Its slow driving me insane.
Problem - CEL 16 "injectors" Basically they are not firing.
I have done the following thus far.
replaced distributor
replaced immobilizer unit
and keys.
dizzy was giving weak spark (that's why it was replaced)
I have since removed the wiring harness to look for faults. i found one on a yellow and black wire with a silver tracer dot. I have now soldered this back up. The wire went into a blue plastic block which connected it to 3 other wires the same colour.
I originally thought that it might be the immobilizer, so I bought a new ecu and immobilizer unit. new keys and a new red key to match it. that didn't work.
I then thought it must be the distributor. as the spark was poor. wasnt that, but now I have a strong spark at least.
I then removed the wiring loom and checked it over.
I found a broken wire, great I thought. as i was beginning to pull my hair out. Turns out that it isn't my problem.
Can anyone help me find the honda workshop manual or wiring diagrams. I thought they would be easy to find but either im blind or they arnt here.
Question is this. what would give cel 16 - anyone ever experienced this?
Someone must be able to help. please please please
Last edited by delsol1; Jun 7, 2009 at 08:51 AM. Reason: additional info and better problem description
Old Jun 7, 2009 | 09:37 AM
Former User's Avatar
Default Re: 96 civic hatch d14 CEL 16 "injectors" Help Needed
Any blown fuses?
Have you checked the main relay. It supplies power not only to the fuel pump but also to the fuel injectors.
Old Jun 9, 2009 | 03:17 PM
delsol1's Avatar
New User
yip realay is a ok.
Old Jun 9, 2009 | 04:24 PM
How do you know the main relay is good?
With the key in ON(II), do you measure battery voltage on the YEL/BLK wire in the connector for each fuel injector?
Is fuse 44, 31, or 13 blown?
Does the wire running between the injector connector and the ECU lack continuity or have a short?
Have you tried swapping in a known good ECU?
Old Jun 9, 2009 | 05:33 PM
omgwtfbbq's Avatar
faulty injectors, or a faulty ecu. do you have someone with the same car that you can sample their ecu with?
Old Jun 10, 2009 | 06:42 PM
SPOOLINmatt's Avatar
im currently throwing cel 16 on an EF and it wont crank, we noticed tonight that the fuel pumo is randomly kicking in on key turnover, the main relay is not working everytime. Gonna try that tomorrow and measure voltage as well.
Old Jun 11, 2009 | 04:45 AM
delsol1's Avatar
New User
I have checked the main realay as per the honda workshop manual. Its good.
I think i have a break in the loom. still checking though
Old Jun 11, 2009 | 06:47 AM
Jimster480's Avatar
is it possible that the injectors are actually bad?
Old Jun 14, 2009 | 06:09 AM
delsol1's Avatar
New User
I have a second ecu and have same problem. I have continuity between the orange wire that goes to a plug on the inlet manifold and the yellow blacl wire on the injectors. i cant see anywhere there is a short on the wire.
I have continuity on the yellow black wires right back to the ecu.
Slowly driving me insane. Time for an auto electrician i think.
Old Jun 14, 2009 | 06:44 AM
Jimster480's Avatar
ya what if the injectors are actually bad or going bad? This happens you know lol
Old Jun 26, 2009 | 12:26 PM
delsol1's Avatar
New User
PROBLEM SOLVED......
I have been around the houses with this problem and I am now gladly saying that the problem is now solved.
It turns out that there is a primary relay which is the power source for the pgmfi main relay.
this had gone.
it is located at the back of the fuse box.
Now I have a sticky idle control valve which i am going to take out and clean up.
Just thought i would let everyone know encase they have similar probs.....
Peter
coltonbarrier
Dec 24, 2013 05:53 AM
awjuhl
10
Mar 9, 2012 08:15 PM
Dancing is Forbidden
Oct 17, 2003 05:43 AM
Artful Dodger
May 30, 2003 01:57 AM
