turning over but nopower at fuel pump
Check the ground on the thermostat. I had a similar issue in my EG, turns out the thermostat ground (which is the ecu ground) was bad. But like it was mentioned earlier, it could also be the main relay.
ok so i got the relay working and now it wont crank when i turn the key, everything turns on and all it just wont turn now when i turn the key, it was turning before i changed the relay and i messed with the cabin fuses and ya now the fuel pump is fine but no crank from the key turning, i fired it up by connecting positive and negative on the starter so it works idk wat went wrong to stop the igintion from working
i had the same problem. it was the fuse that said alt. / solinoid sumthan lol. it was loose and i pushed it back in and it fired right up . or you could just make sure that the fuel pump is plugged up lol
was it under the dash do you remember wat fuse it was like 7.5 or 10 and like where around it was becuase i bought car as a shell and it didnt have that lil fuse map
solofthesouth
Apr 15, 2006 06:32 AM
Joel2204
Nov 11, 2005 01:54 PM
