Changed alternator, now battery light is on
Old Jun 6, 2009 | 07:02 PM
sixgunsound's Avatar
Default Changed alternator, now battery light is on
I got my alternator changed by one of the mechanics at work. I know the new alternator I bought works because I tested it before I even bought it. After about 5 mins of driving my car the battery light turned on and stayed on. It dosnt flash or anything it stays on the entire time the car is running. Anyone know why it would do this, could it be a bad ground or something?
Old Jun 6, 2009 | 07:16 PM
Baserloks's Avatar
Default Re: Changed alternator, now battery light is on
he probably didn't tighten the alternator belt...!!!
Old Jun 7, 2009 | 03:30 AM
Nah it feels pretty tight to me.
Old Jun 7, 2009 | 09:34 AM
Malgerus's Avatar
Sounds like it's not charging properly. When the battery light comes on it means that the voltage is low. Get a voltmeter and test the voltage with the car on and off. It should read around 12.8 volts with the car off, and ~14 with the car running.
Old Jun 7, 2009 | 10:56 AM
skidmarkroyalty's Avatar
^^ditto^^ also check the conections at alternator. if it isnt the belt or the conections then i would have to lean towards a bad alternator. i had a bad alt. on my el camino that tested good 3 times, finally just boght a new one and broblem solved.
Old Jun 7, 2009 | 02:10 PM
samabhi124's Avatar
New User
Check the fittings of the alternator properly. The main problem can be there only.
Old Jun 7, 2009 | 02:38 PM
Baserloks's Avatar
if its not the alternator test out your car battery with a friends battery
Old Jun 7, 2009 | 05:45 PM
Crx Jimmy's Avatar
also the voltage could be too high, that will throw the light on as well.
ZenDog73
May 11, 2012 11:35 AM
90HondaDA
Oct 6, 2010 01:59 PM
89edcivic
Sep 26, 2009 02:38 PM
pstutz
Apr 26, 2003 12:05 PM
KEVlN
Mar 15, 2003 10:07 PM
