99 DX Hatchback 98 D16Y8 Wiring harness Problem
So I installed the motor and harness with the ECU onto my 99 Hatchback and now there seems to be an extra plug for the ECU and I dont kno were to put it.
Also there is no fuel going to the motor, the AUTOMATIC shift light on the dash stay's on 2nd Gear.
I need to kno were did i go wrong? I thought I had everything i needed???
This is the extra Plug that I dont kno were to put
It turns over but doesnt want to send fuel. We Sprayed Starting fluid and it turned so I cant seem to figure out what seems to be the problem.
Side shot of beautiful Intake with the VTEC Solenid.
PLZ HELP!!!!
you cant use that harness. The obd2a harness you have wired up has 3 ecu plugs. The obd2b harness, which should be in your car, has only 2 ecu plugs on the harness. The third ecu plug, is the one you have left over in the picture.
Cliffs: Get the right harness (obd2b 99-00)
your hatch is a 99[obd2b] and the harness u have on there with the motor is a 98[obd2a] the plugs are ddifferent.. use your stock 99 harness and u will have no problems
thats why i transferred everything.....
So ur saying i will have no problems with my D16Y7 Harness?
To the OP, either reuse your stock DX harness and add the vtec wiring, or pick up a '99 - '00 EX automatic harness and use that, you must also use an automatic '99 - '00 P2P ECU.
AGENT 99
Sep 10, 2006 09:36 AM
GOLDBERG
Jun 21, 2005 10:17 AM
