92 Accord EX Tranny Problems
Old Jun 6, 2009 | 06:41 AM
craiger28's Avatar
Default 92 Accord EX Tranny Problems
I do not have an "S" light just a D4 light blinking. It blinks a code 7 and 8. I have replaced the VSS, both shift solenoids, and the TCU. What is the problem? It shifts fine if you shift it manually but when you have in D4 its just in third gear. BTW, does anyone know where to get the transmission codes for this car??
HELP !!!
Old Jun 6, 2009 | 09:47 AM
birdman86's Avatar
Default Re: 92 Accord EX Tranny Problems
Is there anyway you can go to an advanced autoparts or another parts store to get the codes read?
Old Jun 6, 2009 | 01:27 PM
craiger28's Avatar
No. Where can I get the codes???
Old Jun 6, 2009 | 01:43 PM
accord99power's Avatar
google it or use the search in the top right hand side of this page.
Old Jun 8, 2009 | 12:49 PM
craiger28's Avatar
Been there done that, nothing.
Old Jun 8, 2009 | 08:34 PM
KWayRacing's Avatar
You have a bad TCM, or bad wiring to the solenoids(SHift and Torque Converter.) Where did you get your replacement TCM?
Old Jun 9, 2009 | 07:34 AM
Frank Allen's Avatar
You need to get the codes first, also the tcu has to be the right one , different on ex than lx, one over looked thing ive seen in my 92 is the main fuel relay pig tail, some had bad solder joints, also the relay itself, this sends a voltage to the tcu , if its not there then the tcu fails.
Frank allen
Old Jun 12, 2009 | 04:05 PM
KWayRacing's Avatar
bump the above Have seen main relay be the reason and also TCMs are different from year model/ trim level. I always try to match the P/N on the TCM.
92_cb7
Aug 17, 2018 02:55 PM
d9h
Apr 24, 2011 11:12 AM
beeasy12
Mar 21, 2011 01:28 PM
justin3po
Sep 20, 2008 02:54 PM
atc1
Nov 16, 2007 11:55 PM
