New Brembo DC5R (RSX) Front 4-piston calipers with pads and mounting hardware
Old Jun 6, 2009 | 04:02 AM
Dogginator's Avatar
Daisy... Daisy...
Default New Brembo DC5R (RSX) Front 4-piston calipers with pads and mounting hardware
Items:
Brembo DC5R Front, 4-piston Calipers for 300mm x 25mm rotors (new but opened, p/ns 45018-S6M-J51 (R) and 45019-S6M-J51(L))
Pads marked 07.7318.preloaded in the calipers (p/n 45022-S6M-J52)
Mounting bolts (Qty 4, p/n 90107-S6M-J50)
Mounting Bolt Locks (Qty 4, p/n 90651-S6M-J50)
Asking Price:
$750 Shipped to the lower 48, including Paypal fees.
Item Condition:
These are new calipers and mounting hardware that have been opened and loaded with pads. They were test mounted for size and clearance on my car. The condition is 9.9 /10.0 because the coating has two small blemishes. (I will post pictures in the next post because one can only attach five pictures.) Otherwise, these are beautiful, new calipers.
Included items are highlighted in yellow:
Name:  Parts Diagram.jpg
Pictures:
Front of Calipers and mounting hardware:
Name:  DC5R Calipers Front (watermark).jpg
Rear of Calipers:
Name:  DC5R Calipers Back (watermark).jpg
Bottom of calipers:
Name:  DC5R Calipers Bottom (watermark).jpg
Dimensions:
I made a diagram showing the dimensions. They will bolt to a standard Honda hub, as I test fitted them on my '97 DC2 Integra. These should bolt directly to an RSX. You will need to select the proper wheels and rotors for clearance.
Name:  DC5R Brembo Dimensions.JPG
Other Details:
Weight: Each caliper weighs 9 lbs with the pads.
Directionality: These are directional. They are intended to mount behind the front wheels for the bleeders to point up.
Contact:
You can contact me via PM (preferred) or email. Information is here: http://www.hondamarketplace.com/member.php?u=999384571
Last edited by Dogginator; Jun 14, 2009 at 12:01 PM. Reason: Radial dimensions added.
Old Jun 6, 2009 | 04:03 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: New Brembo DC5R (RSX) Front 4-piston calipers with pads and mounting hardware
And now for the small blemishes. They are highlighted in yellow in the pictures.
Old Jun 6, 2009 | 08:24 AM
Fibercation's Avatar
nice item
Old Jun 7, 2009 | 04:14 AM
Dogginator's Avatar
Daisy... Daisy...
Thanks. Morning bump.
Old Jun 8, 2009 | 03:36 AM
Dogginator's Avatar
Daisy... Daisy...
Monday morning bump!
Old Jun 8, 2009 | 07:18 PM
Dogginator's Avatar
Daisy... Daisy...
Caliper weight added.
Old Jun 9, 2009 | 03:29 AM
Dogginator's Avatar
Daisy... Daisy...
Morning bump.
Old Jun 9, 2009 | 10:56 AM
tofu__'s Avatar
if only these fit tsx's!!!!! ahhh **** good deals always out of reach lol
bump
Old Jun 9, 2009 | 11:03 AM
Dogginator's Avatar
Daisy... Daisy...
bump
Yeah. You'd have to machine two new bleeder holes for the directionality. That is not an easy change.
Old Jun 9, 2009 | 11:41 AM
vietxdragon's Avatar
im assuming you test fitted on a non type r integra? so these will fit a gsr then?
Old Jun 10, 2009 | 03:40 AM
Dogginator's Avatar
Daisy... Daisy...
They will fit any Intergra. The probelm is that the directionality is incorrect (you would need to drill and tap new bleeders or bleed the calipers while unmounted). Also a 4x100 pattern will require a custom rotor. The 5x114.3 could use S2000 rotors.
Old Jun 10, 2009 | 08:55 AM
VN712's Avatar
Wow, sick man!!
Old Jun 10, 2009 | 10:01 AM
jvtec95's Avatar
Bleeding calipers upside down isn't that bad, I did it with my NSX calipers.
Sick brakes, too bad I've got RL calipers in my garage or I'd scoop these up!
Old Jun 11, 2009 | 03:27 AM
Dogginator's Avatar
Daisy... Daisy...
Morning bump.
Old Jun 14, 2009 | 12:01 PM
Dogginator's Avatar
Daisy... Daisy...
Old Jun 15, 2009 | 04:55 AM
Dogginator's Avatar
Daisy... Daisy...
Morning bump.
Old Jun 16, 2009 | 03:38 AM
Dogginator's Avatar
Daisy... Daisy...
Morning bump. There is a possible sale today.
Old Jun 16, 2009 | 10:39 AM
hrs-parker's Avatar
good price>>>
Old Jun 16, 2009 | 11:55 AM
Dogginator's Avatar
Daisy... Daisy...
Sale pending.
Old Jun 17, 2009 | 06:55 AM
Dogginator's Avatar
Daisy... Daisy...
This should be the final bump.
Old Jun 17, 2009 | 03:17 PM
Dogginator's Avatar
Daisy... Daisy...
These have been sold!
scanlessfool
Apr 3, 2011 06:02 PM
scanlessfool
Apr 3, 2011 06:01 PM
beav
Suspension & Brakes
May 28, 2008 10:22 AM
