shift play in 1-3-5 help???
Old Jun 5, 2009 | 10:33 PM
whitewonder's Avatar
Default shift play in 1-3-5 help??? (Resloved)
well after my swap from F23a1 to jdm F23a this is my only problem i have yet to solve.
when i shift into 1-3-5 it the shifer wants to go wayyy forward. and from what it looked like the cable is extending out and up out of **** cable harness.
ill be looking at it in the morning when its cold and i can work but any hints on what it could be ?
Old Jun 6, 2009 | 11:49 PM
notAdiesel's Avatar
Default Re: shift play in 1-3-5 help???
my friend had a 97 f250 and there was a plate that got loose and slid down so he couldn't get into 1, 3, or 5(which was reverse on that) so i would def check the linkage
Old Jun 10, 2009 | 09:16 AM
well ... i took out my intake and the braket that is on my thermostat so i could get to it today with a better look at things ... i can just pull on the cable and it moves my stick in the car .. would this just be cable slack or what ?
and if some one could tell me where the adjustment is ... isnt it under the center counsole?
Old May 14, 2010 | 08:58 AM
notAdiesel's Avatar
hey man just wondering how this came out.. my trans grinds going into 1, 3, and 5 like the synchros are not working right and i was wondering if it could be something in the linkage
Old May 15, 2010 | 04:51 AM
well what happened was when i swapped my motor we bent the linkage outa the way and it had bent and it eventually BROKE.
the reason i had to much play in 1 3 5 was cause the cable was not stiff any more at the point where it joins to the I joint at the tranny end, where it eventualy broke.
I went to the JY and got a linkage for 50$ and installed in like 1 hour.
lovin'my type-s
Sep 20, 2007 04:20 PM
H22A4Me
Mar 12, 2006 02:16 PM
h22a193
Jan 27, 2006 12:36 PM
