Engine problem on del sol with gsr engine!
Old Jun 5, 2009 | 06:08 PM
jordo155's Avatar
New User
Default Engine problem on del sol with gsr engine!
I have 93 del sol with a gsr engine. basic mods include header cai and exhaust. On start up it runs great but when it warms up it almost sounds like its missing. There is no check engine light or nothing. Help me please!!!
Old Jun 5, 2009 | 08:54 PM
98civdx's Avatar
Master Detailer
Default Re: Engine problem on del sol with gsr engine!
check the plugs.
replace plugs,wires,cap, and rotor.
Old Jun 6, 2009 | 09:22 AM
Stine's Avatar
Ignitor, coolant temp sensor
Old Jun 6, 2009 | 10:00 AM
jordo155's Avatar
New User
Could it be a fuel related issue? the wires are new msd wires, i havent checked the plugs but they are fairly new.I checked the injectors and they tested good. The car has 270000kms...is it possible that the fuel pump is on its way out?
Old Jun 6, 2009 | 10:15 AM
Stine's Avatar
I think you need to explain the problem a little better. Does the car run great until it gets fully warm then it runs like ****? When you say misfiring does the motor backfire out the exhaust? Or is it a hesitation? Does it have problems just free-reving or only while driving. More info needed!
Old Jun 6, 2009 | 10:42 AM
98civdx's Avatar
Master Detailer
if it was havng fuel problems it most likely wouldnt even run. not just went it gets hot.
my friends nissan did this same thing and i think it ended up being the motor was totaly junk.
the car has 270000kms but how many does the motor have?
Old Jun 6, 2009 | 02:40 PM
jordo155's Avatar
New User
the engine has around 50kms and it ran great untill last week. It runs like it should when its cold. its smooth no hesitation or anything. When it warms up to 120 or so it sounds like its missing. Free idle and when driving. it does backfire when driving. You know how an engine sounds when you have a spark plug wire off or an injector plug off? Thats how it sounds when it warms up. There were some electrical issues in the car. I believe that i fixed those issues but could a bad ground somewhere cause it to be doing weird stuff?
Old Jun 7, 2009 | 11:41 AM
jordo155's Avatar
New User
Does anyone have any ideas on this one???
Old Jun 7, 2009 | 11:54 AM
Former User's Avatar
If you unplug the primary O2 sensor, does the problem go away?
Old Jun 7, 2009 | 07:27 PM
jordo155's Avatar
New User
havent tried that...there is only 1 o2 sensor though
Old Jun 7, 2009 | 07:44 PM
If unplugging the O2 sensor eliminates the problem, then replace the O2 sensor.
86aw11
Dec 28, 2015 05:35 PM
kwolf15
14
Sep 22, 2011 05:23 PM
TunerFreak24
19
Nov 17, 2010 09:06 PM
oluc12
Mar 15, 2010 10:01 AM
xboxhaxorz
May 23, 2008 07:16 AM
