diy motor tensioner/shock absorber
Who the fack changed my title?!
has any one tried this before? im thinking about doing this so i will have less play in the rocking of my motor. im getting pretty tired of replacing my tps sensors. i know the auto parts stores have a wide wariety of gas shocks for hatches, hoods, and what not.
any info/opinions/experience on doing this would be nice
i did already but i want my stuff to be rock solid. i really dont have much clearance and when i launch i can hear/feel the motor move
theres a few tricks out there. u cud cut a rubber hose and wedge it where the mount is (not rock solid, but stiffer). there is some type of filler people use to create solid mounts from oem ones.
Go and get you a tube of 3M's window weld and pull your mounts out and fill them.. Wala cheap POLY mounts. If you notice that much movement your mounts are toasted. Especially a Z6,all 110whp of fury..
and actually i just got finished searching the diy's here so i think im gonna try that stuff
superturboprelude
Jan 6, 2004 11:37 AM
on the 3m window weld. If you are staying street this is a GOOD upgrade, but won't help you much if your going to go pro.
