f20b vs h22a
Old Jun 5, 2009 | 10:22 AM
2.2lude88's Avatar
Default f20b vs h22a
ok i have a jdm h22 swap in my 93 lude and i like it but...i was just seein opinions on a f20b swap because i was gonna do one in my other lude..does it make more or less power? is the h22a better or f20b? thanks!
Old Jun 5, 2009 | 10:27 AM
Rude Awakening's Avatar
Daughter not possible
Default Re: f20b vs h22a
Most F20B's come with automatics attached. Those are 180 HP. Manual is 200 HP.
Unless you find a manual one, which will cost ALOT since the tranny's LSD, you might as well get the H22A.
Old Jun 5, 2009 | 10:29 AM
minilogoguy18's Avatar
F20b has the same power but at a higher rpm, H22a has more torque as well.
Old Jun 5, 2009 | 10:34 AM
2.2lude88's Avatar
well there is a guy from around here that had one in a hatchback that ran a h23 tranny! i know that you can use h series trannys on them so i was just gonna order a long block and use either my h23 or h22 tranny! but are you sure they are 180hp with a auto tranny and 200hp with a 5 spd.?
Old Jun 9, 2009 | 11:11 PM
bsivoljr's Avatar
yEAH The Sir is Auto making 180 and the Sir-T is Manny making 200hp
Old Jun 9, 2009 | 11:16 PM
fatboy1185's Avatar
Big Cat
only difference is the cams and intake mani. slap some type s cams, skunk2 mani and tb and you're good to go.
Old Jun 9, 2009 | 11:26 PM
The Captain's Avatar
...because cams and intake mani change the displacement.
Please dont spread incorrect information.
Old Jun 10, 2009 | 01:32 AM
fatboy1185's Avatar
Big Cat
I was responding to the comments on the 20 horse power difference from auto to manual. I put down 192 on a dyno dynamics.... with just off shelf bolt on's and a crappy street tune. trap 99mph in a 3100lb accord. The f20b is a very capable engine.
Old Jun 10, 2009 | 04:17 AM
carnot's Avatar
The f-series engines also come with cast iron sleeves which may interest you if you are planning on putting forged pistons in at some point.
Old Jun 10, 2009 | 07:38 AM
NirVTEC's Avatar
2.2>2.0
/done
Iron Sleeves......OoOoO.......big whip!
When will you kids learn?.......No replacement for displacement!
Old Jun 10, 2009 | 07:47 AM
carnot's Avatar
Good point....drop a small block chevy in there!
Old Jun 10, 2009 | 08:01 AM
NirVTEC's Avatar
Now that you can buy a 434 SB Chevy crate motor......Why not?!?!
Look into the H23A if you're looking for a fun motor! Great powerband! more TQ and about 500rpms sooner than an H22A.
Old Jun 10, 2009 | 08:03 AM
su8854's Avatar
h22 pwns
Old Jun 10, 2009 | 09:13 AM
NirVTEC's Avatar
Originally Posted by su8854
h22 pwns
I knew I missed something about HT.com!
Noobs rule!......great job with the "p" instead of "o"
Brownjd
Jan 27, 2011 07:09 AM
H22 EH!
Mar 12, 2005 06:18 AM
ozzyman
Aug 9, 2003 04:25 PM
foxedogg
Jul 16, 2003 05:43 PM
