b16 block rebuild questions (searched)
i spun a rod bearing and well da crank is .01 thousands so i got a new crank and bearings and piston rings but before i assemble it all i wanna know wat i need to do to da block.
hot tank it? hone it? any info would be helpful thanx in advaced.
buy a helms manual for a del sol or a civic (something with a B16) pick up some micro meter's a bore Gauge and some plasta gauge to double check. yes hone it and check the cylinders to make sure it doesn't have to be bored also look into a new oil pump if you spun a bearing yours is most likely scared and wont work as well.
good luck
good luck
Sorry to hear about the motor
To be done right you need to disassenble the entire motor and have it all cleaned. All of the oil passages are probably full of metal. If you just bolt new stuff on then the metal will scare/ruin the new crank and so forth.
Although the metal that is in there now has probably already scored cylinder walls, Cams and all the other bearing surfaces. You really need to check the entire motor.
Good Luck.
Good Luck.
JDM Lyfestyle
May 4, 2009 08:30 PM
swpdb16
Mar 2, 2004 12:45 PM
