88-89 bumpers on a 90-91 hatch question
Old Jun 4, 2009 | 09:58 PM
CORE132's Avatar
Icon2 88-89 bumpers on a 90-91 hatch question
i know that the 88-89 and the 90-91 have quite a few slight differences to them, and i was wondering if i would be able to use 88/89 front and rear bumpers on my 90 hatch.
Old Jun 4, 2009 | 10:05 PM
Orangegsx's Avatar
Default Re: 88-89 bumpers on a 90-91 hatch question
I had them on my 90 si for a while. It fit in the back fine. In the front I was running no bumper support so I'm not sure If they will work if you have yours on still. Most likely though.
Old Jun 4, 2009 | 10:14 PM
CORE132's Avatar
then how was it mounted if u had a bumper support?
n how would the 90 bumpers fit in an 88 hatch?
Old Jun 5, 2009 | 01:08 AM
24TEN's Avatar
PHANTOM MENACE
You use the bumper support that is matched to the bumper. I have an 88-89 bumper on my 91 hatch. Originally I used the 91 support but it was off (90-91 bumper sticks out further), I then replaced it with the support that matched the bumper and it fit fine. Same with the rear bumper. The major fitment issues for the rear bumper are with the brackets that attach to the bottom portion of the bumper, 90-91 brackets go lower slightly because the 90-91 bumper is lower (by like half an inch to an inch, I don't really remember).
Old Jun 5, 2009 | 01:42 AM
4DRmafia's Avatar
88-89 bumpers look better than the 90-91 in my own opinion. I need a front one, anybody want to sell me one?
Old Jun 5, 2009 | 09:12 AM
CORE132's Avatar
Ok so I should trade my friend the bumpers with the support n everything on both front n back?
Old Jun 5, 2009 | 09:25 AM
Orangegsx's Avatar
Mine fit fine in the back without changing the support. Just make sure you use the right foam. Change the front support for sure.
Old Jun 5, 2009 | 11:18 AM
CORE132's Avatar
ok cool n does anyone know how to take the moldings with out damaging?
Old Jun 5, 2009 | 01:22 PM
Orangegsx's Avatar
I do them from the inside. Remove the interior panels and release the clips one by one.
Old Jun 5, 2009 | 01:44 PM
24TEN's Avatar
PHANTOM MENACE
You can try to use two flatheads to squeeze the clips to pop out of the door from the outside. The correct tool looks sort of like a two tooth fork, split like a snake's tongue (sorry, don't know how else to describe it). The way I took mine out was I took off the one bolt in the doorjamb and tapped the molding forward until it came out. This only worked for me because the clips were facing the same direction on my molding and I'm guessing that they are like that from the factory too but use this technique at your own risk.
scootr
Jan 23, 2017 10:47 PM
I LUV MY EJ1
Oct 18, 2009 05:49 AM
HONDAlover369
Jul 31, 2008 10:21 AM
Radim
Jun 11, 2008 09:35 PM
crxmadman
22
Sep 26, 2003 09:15 PM
