ITR - factory valve seat angles
Old Jun 4, 2009 | 05:28 PM
vinuneuro's Avatar
Default ITR - factory valve seat angles
Are they the same as regular B18c's or not? A couple of different publications say the 'the valve seat was changed from 60 to 45 degrees.'
The cyl head section in the helms shows the same valve seat specs for B18b, B18c1 and B18c5. But if you look in the the first few chapters, the specifications section, the ITR valve seat widths are different. Since valve seat angles aren't normally listed in this section though, there's no way of knowing about them.
So anyone know what the deal is with ITR valve seats?
Old Jun 5, 2009 | 04:34 AM
hybrid_KJ's Avatar
Default Re: ITR - factory valve seat angles
From memory I believe it is 30-45-65 for ITR intake.
Old Jun 5, 2009 | 05:01 AM
EK9 CTR's Avatar
The valve set angle was changed from 60 degrees to 45 degrees to help aid in airflow...
Old Jun 5, 2009 | 07:25 AM
Phil M's Avatar
Negative.
Old Jun 5, 2009 | 07:55 AM
EK9 CTR's Avatar
Originally Posted by Phil M
Negative.
So, you're saying that they were'nt changed?
Old Jun 5, 2009 | 09:45 AM
092eg6's Avatar
phil let em kno
Old Jun 5, 2009 | 09:56 AM
omniman's Avatar
The valve seat angles were changed from 30,45,60 degrees to 30,45,65 degrees to help aid in airflow, in addition the seat throats were opened up .25mm and blended to the port to help improve airflow...
i edited it for you so you have correct info
Old Jun 5, 2009 | 10:19 AM
vinuneuro's Avatar
Thank you.
Old Jun 5, 2009 | 10:38 AM
Rocket's Avatar
It's part of the "package" Honda to work together with more lift and duration from ITR cams, increased compression, raised rev limit, revised intake valve etc.
Remember, it works as a package.
Old Jun 5, 2009 | 11:11 AM
vinuneuro's Avatar
I definitely understand that.
Actually I don't even have a B motor. Interested in the H22 Type-S since it got the same modifications (compression, lift, minor port work, higher resulting peak power etc) as the ITR did, and has the same thing listed regarding revised valve seat angles in it's literature. I wonder if the seat specs are the same as the ITR.
dfoxengr
Jun 20, 2006 05:05 PM
XBoostedAccordX
Sep 29, 2003 05:01 PM
se93
Mar 31, 2002 10:25 AM
